Ways to change axle size.
smegballs
PostPosted: 23:25 - 17 Sep 2015    Post subject: Ways to change axle size. Reply with quote
So say you needed to get a 17mm axled wheel into a swingarm that took a 15mm axle. How would you go about it? More for theory than actual bike application atm.
So far thought of:
1. Bush the 15mm axle with a 17mm OD x 1mm wall tube
2. Replace the 17mm bore bearings with 15mm bore ones, if they can be found with equal outer race diameter.
3. File 2mm off the bottom of the swingarm slot to get clearance.
4. File/grind flats on the axle to fit in swingarm slot.
Any more ideas? Advantage/Disadvantages of methods??
Major Doss
PostPosted: 01:11 - 18 Sep 2015    Post subject: Reply with quote
Bearings all day long. Available, in this application it reduces rotational speed of bearings, reduces load.
winwinwin Thumbs Up
Shim 1mm spacer for easy life, but you're replacing bearings anyroadup, no?
davebike
PostPosted: 08:20 - 18 Sep 2015    Post subject: Reply with quote
As said bearings also you will be to drill out or replace the spacer between the bearings
If not and you going up in size modify ie cut /file the swing arm
Yes I have done this both ways Smile)
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 11 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 14 - Page Size: 35.24 Kb
