DT175MX - Too far gone?
mudcow007
PostPosted: 20:23 - 24 Sep 2015    Post subject: DT175MX - Too far gone? Reply with quote
So, i was given this last year
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193643_zps2777bd73.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193700_zps8d22d34d.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130831_193648_zpsb6b7456e.jpg
It's a DT175MX 1979 single shock
it had sat in a garden for about 8 years (I reckon longer) on its side, flywheel up (without that side of the casing on) uncovered an unloved
The bloke who gave me it said he bought it with his paper round money an was genuinely gutted to see it go - cant see why
Anyways, as soon as i got it home took the engine out an left it as that
fast forward to tonight an thought I would attack it
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_170753_zpstu9dbf6f.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_170657_zps2cqtzdln.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_170633_zpslzaoesof.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_170646_zpswzmxap4u.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_170622_zps7htfhz5v.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_190818_zpsfkduk6ie.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_190806_zpskuom9qro.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_190824_001_zpsvwqv55gq.jpg
After fighting with rusted rounded off screws, I managed to get the clutch side cover off Shocked Crying or Very sad
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_193015_zpslmenbuyx.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_193007_zpsu9qsmbdb.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150924_195219_zpsf6oev1bu.jpg
I reckon it will need new clutch plates......
Fisty
PostPosted: 22:48 - 24 Sep 2015    Post subject: Reply with quote
Weigh it in.
It's more fucked than Ste's mind.
Fatter and faster than Fret
stevo as b4
PostPosted: 23:31 - 24 Sep 2015    Post subject: Reply with quote
I hate to agree with Fisty's prognosis, but damn he's right.
You could sink £££'s in parts into the motor, and then still need to repair the clutch cable holding bracket, replace the clutch assembly/basket and have all the services done like blasting, re-bores, skimming etc.
You'd find a better motor to freshen up far cheaper I reckon.
The swing arm and frame might clean up be ok once de-rusted, but if they are riddled with rot they are not worth repairing either.
Even if the frame was ok, and the motor had been better, in my opinion that bike is only ever economically going to be a field bike. To replace and source all the missing bits to make it a std original road bike would be thousands!
if you were doing it as a field bike, at least you could use generic aftermarket plastics, make you own seat base and fit bits from other dirt bikes, that would not affect it's value too much.
dangerousdave
PostPosted: 00:38 - 25 Sep 2015    Post subject: Reply with quote
these are valuable bikes but i dont think there is too much there that can be salvaged.
it might be useful to somebody who is trying to rebuild one as a source of a few spare parts, if it was cheap enough.
its a shame it was not looked after.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
mudcow007
PostPosted: 08:55 - 25 Sep 2015    Post subject: Reply with quote
It's not looking too pretty I have to admit
I will leave it in a bucket of kerosene/ paraffin n' stuff, an see what happens - this wont cost me anything so i might aswell
RE. the clutch cable bracket
here the exhaust bolts to the head has been snapped off aswell Sad
I think the whole project may just be a "oh whats inside a two stroke engine" an leave it as that
Although i would really like to get it back motoring
grr666
PostPosted: 11:08 - 25 Sep 2015    Post subject: Reply with quote
Sure it wasn't parked in a lake for 8 years?
That's fucked.
Matt B
PostPosted: 11:58 - 25 Sep 2015    Post subject: Reply with quote
What do you class as valuable? Restored minters can be found for under £2k, less than you would need to throw at that one to get it sorted.
mudcow007
PostPosted: 20:18 - 02 Oct 2015    Post subject: Reply with quote
Update
after having a parrafin/ kerasene bath for a week or so, got fed up of the stink so drained the tank an started stripping it
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20151002_190440_zpsftmzqrpb.jpg
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20151002_193744_zps5pqgimwz.jpg
bit stuck now, im gonna have to pull off the flywheel but the locking nut seems solid, gonna try some heat i think
also there are aluminium bolts? holding the head on, got three off but the last one is chewed Sad
still haven't shelled out on parts or anything as i don't know what i will find if I ever get to split the cases
mudcow007
PostPosted: 16:37 - 08 Oct 2015    Post subject: Reply with quote
Im going to split the cases an see what i find in there, found a bit of rust on the back of the clutch basket, thats bout it on that side......
Its the genny side that is bad Sad
it hasnt cost me anything yet so i will just have a fiddle around with it
Oh an I thought the single rear shock was earlier than the twin shock - I may be wrong though
TheSmiler
PostPosted: 20:28 - 08 Oct 2015    Post subject: Reply with quote
Personally I'd get rid wouldn't intend on using it as a full project. However if you are getting rid I'd agree with Vincent there is nothing wrong having a look in the engine if you are inquisitive.
mudcow007
PostPosted: 13:19 - 20 Oct 2015    Post subject: Reply with quote
update
made/ bodged a piston/ barrel seperator - to try an get out the piston from the barrel...
also
just got a replacement bottom end of an engine for £50
anyone any ideas how i can remove the flywheel when it hasn't got threads anymore for my extractor?
Sean.S
PostPosted: 00:28 - 21 Oct 2015    Post subject: Reply with quote
I wouldnt like to take that on, but it looks like you're off to a good start
Subbed for more updates
bypass2
PostPosted: 00:47 - 21 Oct 2015    Post subject: Reply with quote
What about a gear puller you can get them with 2arm puller or 3arm puller. thats what i have used to get the flywheels off
mudcow007
PostPosted: 09:16 - 23 Oct 2015    Post subject: Reply with quote
Replacement/ donor engine has arrived an looks a million percent better than mine.
Think i will just swap the case over with the number (so they all match) an use this
It even still has its oil pump installed Very Happy
Notice on the top of the piston on the new engine its stamped "100" i'm guessing that is 1.00 so its been rebored at somepoint?
I tried a puller last night, but coudlnt get it to "grab" the case was in the way...will have another go tonight
cheers
UncleFester
PostPosted: 09:22 - 23 Oct 2015    Post subject: Reply with quote
As long as you have paperwork for it ..... you can make a good bike out of the paperwork
It just might not be 100% 'that' bike Mr. Green
Why not clean it up, get it to a point where it looks like it might be worth someone else taking it on and get as much as you can for it?
2017 Z1000SX
mudcow007
PostPosted: 10:30 - 23 Oct 2015    Post subject: Reply with quote
Aye, on the "new" engine the number has been err body filled over Shocked
but, this bit gets confusing....
My LH case is scrap, but the LH case on the new engine is good.
keep my RH case (with numbers matching frame) and fit to new LH case for the win?
Going to sound thick this, but....... A rebore would only effect the head/ barrel an has no bearing on the bottom end doesn't it?
mudcow007
PostPosted: 11:48 - 23 Oct 2015    Post subject: Reply with quote
Cheers Vincent Thumbs Up
On my (old) engine, the barrel is still on with the seize/ rusted in piston - so its locked/ doesnt move
The nut has been removed on my flywheel, but i cant get my extractor to screw into it to pop it off
Bit gutted that you cant just chop an change engine cases....will see how they look together once i have the flywheel(s) removed from both engines.
The last post was made 10 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 137.99 Kb
