Bandit Headlight
sparkywilliam...
PostPosted: 22:54 - 02 Oct 2015    Post subject: Bandit Headlight Reply with quote
[i]Hello all,
I have split my headlamp on my mk2 faired bandit to re-attach some wayward screws that had come off the brackets that holds the glass lens' inside.I have done both sides.
I had to obviously wind out all the screws,and so obviously the lens on both sides will be totally,totally out of skew, so could;
Someone please give me an idiots guide as as to how to set them back up to near as damn-it.
I have currently wound the screws all the way in so the bracket is as deep as it will go into the rear of the unit.Are there a set number of turns in before you do fine adjustment etc. Can you tell i haven't a scooby? ( i have labelled the screws with numbers in the pictures i've attached if it helps)
Also the glue is super sticky and i have tried to remove as much as i can but any top tips on what to use to re-assemble or shall i just re-heat it with paint stripper gun and re-assemble with what glue is left on it. I was thinking clear sealant just to keep weather out.
thanks
Previously CG125,YBR125 Now GSF600 Bandit
The last post was made 10 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 14 - Page Size: 32.7 Kb
