Help new mirror
ukbertie
PostPosted: 09:46 - 10 Oct 2015    Post subject: Help new mirror Reply with quote
i have just bought some new mirrors for my Harley Fxrs , i undid the original ones , when i went to put news ones on the one by the throttle fitted perfectly and tightened up as it should , the other one was very loose so i put some thread lock on but it stll isnt tight , i have checked the size and they are both the same , i took it of and tried it on the throttle side and it fitted like it should , so i think the hole on clutch side is slightly bigger, does anybody know of a way i can make either the mirror stem a bit wider or the hole smaller .
Ben90
PostPosted: 09:50 - 10 Oct 2015    Post subject: Reply with quote
By any chance did you over tighten the left-handed thread* while trying to undo it and strip the thread?
*That is if Harley do reverse threads on the left mirrors like other manufacturers. Hold the bolts together, do they slope in the same direction?
Edit:
Ignore the above. Doh!
Yamaha FZ6 S2
ukbertie
PostPosted: 10:01 - 10 Oct 2015    Post subject: thread Reply with quote
they dont have bolts on they screw into the housing . i would drill out the hole and put a bolt on the bottom but the tread on mirror stem is not long enough to go through the housing
Ariel Badger
PostPosted: 10:15 - 10 Oct 2015    Post subject: Reply with quote
It sounds like it needs to be shimmed up a touch. My clutch lever is forever coming slack on the bars and I shim it with a bit of emery cloth, a leather tassel would do the job fine.
The last post was made 11 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.88 - MySQL Queries: 14 - Page Size: 39.08 Kb
