Dalemac |
Dalemac World Chat Champion
Nexus Icon |
Nexus Icon World Chat Champion
Wonko The Sane |
Wonko The Sane World Chat Champion
Posted: 20:53 - 25 Oct 2015 Post subject: |
I was advised by a good friend to use IKEA for kitchens and I regret not taking his advice.
avoid Wren, if there's any problem they have two responses:
1) 'Our contract is only for supply of the kitchen' when in actual fact they arranged the install with a local 'fitter'
2) 'Our kitchen planners are not professionals' ok, so why am I paying them to design me a kitchen that doesn't fit?
so, back on track,
it's a matter of planning movement from start to finish of your kitchen, for example going from fridge to prep to cook to wash.
yes a gas hob will fit above any appliance as they simply sink into the worktop and don't protrude much below - it's more common to fit them above a fitted oven. You'll need gas supply and electric supply (for the igniter) ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
Dalemac |
Liono |
Liono Spanner Monkey
Rockhopper |
Rockhopper Trackday Trickster
Codemonkey |
Codemonkey Crazy Courier
Posted: 13:52 - 26 Oct 2015 Post subject: |
My mums partner was a joiner / kitchen fitter and he suggested to stay well clear of Ikea kitchens due to the lack of space behind the carcasses for the services, though I can definitely see the appeal of being able to pop along to one of the stores and pick up whatever bits you need rather than having to place an order for everything with one company and wait for it all to turn up..
To be completely opposite to Wonko The Sane, I opted for a Wren kitchen and fitted it all myself, I posted at the time here:
https://www.bikechatforums.com/viewtopic.php?t=224681&postdays=0&postorder=asc&start=0 ____________________ Test Passed 10/05/2011 Current bike: XJ6-N |
Rogue_Shadow |
Rogue_Shadow World Chat Champion
Posted: 14:22 - 26 Oct 2015 Post subject: |
Heard good things about Wickes.
Not the first name you would think of when thinking about a new kitchen, but having been in a couple I would recommend having a look. |
DrDonnyBrago |
DrDonnyBrago World Chat Champion
Tracey Suntan-King |
Tracey Suntan-King World Chat Champion
weasley |
weasley World Chat Champion
Posted: 15:14 - 26 Oct 2015 Post subject: |
First - my experience: a couple of years ago we bought and ground-up renovated a house. This included designing, selecting and overseeing installation of a kitchen in an open-plan kitchen/dining/living space.
Integrated appliances - you generally have to buy the "integrated" variant of such appliances. These have unfinished front doors and appropriately-located displays/controls that will accept the door panels of whatever kitchen you are fitting. We got an integrated dishwasher and microwave (mounted at about chest height) but went for a properly showing-off, stainless steel, American-style fridge freezer. We 'concealed' the washing machine and tumble drier in a utility room.
If you are concealing a f/freezer you need to be aware of the door hinge arrangement. Many regular fridge doors require a 50 mm gap to the side of the fridge to allow the door to open fully. Some have hinges designed to open the doors within their own footprint, so can be close-fitted to units.
I was dead-set on having a high-level oven mounted in a unit, but in the end we got a 90 cm range cooker and love it. However, if you only have space for a regular 60 cm cooker, I would deffo go with an integrated oven with separate (wider) hob. I would also go with induction over gas. That's from someone who was a massive fan of gas, but am now evangelical about induction hobs. Mostly because they are as controllable as gas but approximately googolplex times easier to clean and use. Yes, you need special pots and pans, but these are easy to find. If anything does spill over, you can wipe it up there and then, as you continue to cook. They easily mount over other units and are basically flush with the work-surface. And dat piano-black finish... We also got a custom-made glass splashback made to go behind the hob, colour-matched to the wall paint. Make sure the wiring and fusing to the kitchen is up to the job though - a 5-ring induction hob with two fan ovens and a grill can make a hefty load!
When siting your hob, think about extraction. We were only ever going to have an extractor that actually extracted (to outside) rather than a recirculator (which filters and recirculates the air). It means you have to put the cooker on an exterior wall (or one where you can run an extraction duct to an exterior wall) but for a kitchen/living space we wanted as much as possible to keep odours down, and full extraction offers better air flow. The only time we get any issues is when searing steaks or doing any really hot grilling.
Someone I work with is using IKEA's kitchen design app and has noted the lack of service space, plus he says that their units are the same depth as their worktops, to there's no scope for an overhang on the worktop over the front.
Worktops - we went for Silestone, a kind of 'synthetic' stone composite. It is easy to clean and pretty resistant to stains, but is hard and will chip or break cups/glasses etc if dropped even a little.
Flooring - we used Polyflor vinyl planks in an oak effect - they are warm, look just like wood, are resilient and are easy to clean. If they should need repairing then this can be done fairly easily.
Think about lighting - mean and moody does not work in a kitchen; you want lots of light in the right places, and diffuse if you can (rather than stark spotlighting). We have 8 pendants hung in 2 rows of 4 for main lighting and LED strip lighting under the high level cabinets. This helps with light on the work surfaces but also looks good if the kitchen is being used as a social space for partying, with the main lights off. If possible wire under-unit lighting into a room light switch and get the wiring run into the walls before fitting the units.
Have a think about how the kitchen demarcates from the living room. We put a 'return' peninsular jutting into the room - this is effectively the missing 'wall' of the kitchen and also acts as a breakfast bar and additional working space - the worktop overhangs about 300 mm onto the 'living' side and we have some bar stools underneath.
Think about futureproofness. Will you want a smart fridge? Or anything else that might want ethernet connectivity? If so, run it now. Also have lots and lots of wall plugs, in the right places.
One thing we got wrong was where to put mundane stuff like hand towels and a bin; we never thought about it and consequently have tea-towels draped over the oven door handle and a free-standing bin just kind of sat there - learn from my mistake.
Have a look into the options for corner units. There are plenty of slidey-spinney devices that allow you to get stuff in and out easily, but we felt they robbed a lot of space, so just went for plain corner units with a door on each face - less-frequently used stuff goes in these.
We got our kitchen from Benchmarx. They supply only to the trade, but will work with you to design and select everything so long as it gets ordered by a tradesman - builder, fitter, joiner etc. They tend to have showrooms at Travis Perkins locations.
We bought our appliances from Euronics - they were happy to negotiate on price and we got a good deal since we were ordering en masse.
We have been using ours for a couple of years now and aside form the small practical issues mentioned, having designed and decided everything in there, it all just works for us. There's always a plug nearby, there's enough space for everything and we're very happy with it. ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
hedgehugger |
hedgehugger World Chat Champion
Posted: 15:38 - 26 Oct 2015 Post subject: |
I've an integrated oven at about waist - chest height. It's great, no more bending down. Cupboard underneath and one overhead, neither suffer with any oven heat problems (don't keep food in them, just oveny stuff and general kitchen detritus).
The hob sits over a cupboard. Doesn't get too warm in there. Never actually tried to touch the hob from underneath when it's on though. I guess with enough clearance a dishwasher would be ok underneath.
I was always a fan of gas, but OMG, the convenience of a ceramic hob, so much cleaner, no more black bottomed pans, somewhere to dump all the junk you bring home when the hobs not on
I originally looked for an American style fridge, but couldn't find one with enough freezer space, so I have huge things, free standing, not integrated. |
grr666 |
grr666 Super Spammer
Posted: 20:48 - 26 Oct 2015 Post subject: |
I would only fit integrated oven and hob personally. Have done integrated appliances before but they are a faff
especially washing machines. +1 on benchmarx, I worked in their Dagenham branch for a while, they are owned
by Travis Perkins, but the EXACT same kitchens
are on sale at wickes (also TP group by the way as is city plumbing) If you look at the packaging of the facias
they have 2 different range names printed on them. A good feature of their carcasses is that they have a 50mm
service gap behind them and a full 18mm thick back panel. Plus 25 year guarantee, and soft close doors and drawers
as standard. Also the benchmarx carcasses come assembled so it saves quite a bit of time on installation.
Their appliances aren't particularly good value though. Better sourcing those elsewhere. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Wonko The Sane |
fair enough, I speak only from my own experience which is as follows:
a corner unit that isn't a corner unit as corner units don't exist in the range I bought despite being told it was a corner unit - this only came to light after fitting, the handles prevent the doors opening as a result.
from wren's point of view that and the waste pipe is the only fail.
From the fitting point of view, it was fitted in 2013, however no prep work was undertaken before the kitchen went in (despite this being discussed prior) and the waste pipe from the sink / dishwasher 'wouldn't fit' behind the dishwasher so it was simply taken through the wall of the kitchen…
into the conservetory where it ran along the wall for over a meter into the drain boxing in the corner (where the existing waste had popped through)
Since then I've met more people in the area and gotten to know them, one of whom is my husband of my wife's best friend living just down the road, he's an electrician and her brother is a joiner who's recently started producing his own kitchen units and fitting so I'm now, tow years later paying for people I trust to re-fit my kitchen instead of the muppets wren recommended.
As Wren have washed their hands of the issue and no longer return my calls (despite me still getting calls about my up-coming fitting / delivery as they seem to attach my number to every other order) I feel I'm justifiably pissed off with them
my experience with IKEA kitchens is a house I 'renovated' (dad did more work than me as it was next door to his house) to attempt to let
mum wasn't happy as she'd just had a new kitchen and preferred the IKEA units I was having put in, they then moved house and fell out with Howdens over their inability to get any part of the order correct delaying the kitchen to 3 weeks after they should have moved into the new house.
The mate who recommended IKEA kitchens loves them as IKEA have just paid to replace ALL the doors on the units because two doors have peeled after 8 years!
no questions asked, straight forward offer of replacement with option of £45 to upgrade to the 'nicer' veneers ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
Dalemac |
Stalk |
Stalk Brolly Dolly
Ichy |
Ichy World Chat Champion
Posted: 10:20 - 29 Oct 2015 Post subject: |
We had an all integrated kitchen but couldn't really see the benefits. It would have been a pain to source replacements and fit them if anything broke.
Last year we completely gutted the kitchen and fitted a new one from Ikea, I had used they before and was happy with the quality. The design software is dead on. I probably spent two weeks changing stuff to give us what we wanted but it was easy to do. It generates an order list that you take in store or they can access your design in the shop.
Service was spot on. Delivered when they promised. I had a couple of bits missing from delivery but a phone call and they were posted out without a problem. 2 months later, when I got around to fitting, I noticed another bit missing. Another phone call and it was in the post FOC. Two damaged doors? Collected and replaced FOC. Even after finishing they will take back any unused bits and refund the full value.
The other benefit is that the carcasses are standard sizes. If I decide to update the kitchen then I only really need to replace the doors.
The service space was fine for me. I just moved a couple of pipes around to make them fit and used the space under the cupboards for the larger waste and heating pipes. Took me about two weeks including doing the wiring, plumbing, underfloor heating and tiling. I did need someone to help me lift some of the bigger cupboards. and I got someone in to fit the worksurface, cost about £60.
[https://i93.photobucket.com/albums/l41/marki_03/Armstrong/P8060526_zpsz1rmb4jn.jpg
https://i93.photobucket.com/albums/l41/marki_03/Armstrong/P1010005_zpsltb3zlqq.jpg ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
There is a gap of 4 years, 238 days between these two posts... |
Riejufixing |
The last post was made 3 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
