Bleeding electric oil pump?
Old Git Racing
PostPosted: 10:17 - 31 Oct 2015    Post subject: Bleeding electric oil pump? Reply with quote
Peugeot speedfight 3 air cooled, how do you bleed the electric 2 stroke oil pump?
OGR
WD Forte
PostPosted: 15:10 - 31 Oct 2015    Post subject: Reply with quote
I sorted out a neighbours scoot a while back and had the same problem.
Eventually I found I had to keep something pressed for 30-45 seconds or so as I turned on the ignition.
My dim memory says it was the starter button I had to keep pressed.
As none of the brake levers was used it didn't try to start the engine
and after a while started to prime the oil pump.
Perhaps you have to do something similar?
HTH
EDIT:
Thinking about it while walking up the shops and back.
I had to hold the throttle fully open at turn on not press the starter !
It was an Aprilia 50cc injected model so had a tps
Not sure if any use or relevance in priming the Pug
bikers smell of wee
.. This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 11 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.4 - MySQL Queries: 14 - Page Size: 35.6 Kb
