Help tzr dtr
Dtr1251000
PostPosted: 10:16 - 02 Nov 2015    Post subject: Help tzr dtr Reply with quote
Hello people
Will a tzr cdi work in my 1999 dtr my original cdi 3 plugs would I be able to wire the tzr one to my DTR? Or any other cdi can't get bike to spark changed ignition coil and stator and pick up lead and plug still no spark so must be cdi also power valve servo won't turn only by hand so this makes me think cdi after all the tests I've done
Thanks in advance guys.
Dan
Val
PostPosted: 10:40 - 02 Nov 2015    Post subject: Reply with quote
can't help with tzr, but you can buy dtr cdi from ebay about £30. Have you changed the spark plug by any chance?
Dtr1251000
PostPosted: 11:27 - 02 Nov 2015    Post subject: Reply with quote
Hello val thank you for your time, yes it has a new spark, new stator generator, new ignition coil, but the cdis from eBay are not the right plug connections could I just change the plugs over to fit my bikes connections from my old cdi,
Dan
Val
PostPosted: 18:29 - 02 Nov 2015    Post subject: Reply with quote
Hello Dan cdi can be exchanged by principle, even there some companies that do custom CDIs. You will need your current cdi schematics if you want to search for exchange yourself.
The more simple way is contact these guys:
https://www.electrexworld.co.uk/
with your VIN number and details about your current cdi and the details about your current power valve like model numbers etc.
Dtr1251000
PostPosted: 20:03 - 02 Nov 2015    Post subject: Reply with quote
Thanks you I will contact these guys in the morning, val would my power valve not do it tet/clean cycle because of the broken cdi, also I can run it by hand easy. Many thanks for you time and knowledgeknowledge. Dan
Dan
The last post was made 11 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.2 - MySQL Queries: 13 - Page Size: 43.73 Kb
