DNSCrypt Proxy
ScaredyCat
PostPosted: 19:16 - 04 Nov 2015    Post subject: DNSCrypt Proxy Reply with quote
Just a quick one, if you fancy using your raspberry pi (you can use almost any machine to do this just check out https://dnscrypt.org for all the clients) to encrypt your DNS lookups. This prevents people from spoofing dns and encrypts the actual dns packet content.
Create a work directory and move to it
Code:
mkdir dnsc && cd dnsc
Get libsodium
Code:
wget http://download.libsodium.org/libsodium/releases/libsodium-1.0.6.tar.gz
extract it
Code:
tar -zxvf libsodium-1.0.6.tar.gz
build and install it
Code:
cd libsodium-1.0.6
./configure
make
make install
make sure you run
Code:
ldconfig
to refresh the library cache.
move back to your work dir
Code:
cd ..
Now, get dnscrypt proxy
Code:
wget http://download.dnscrypt.org/dnscrypt-proxy/dnscrypt-proxy-1.6.0.tar.gz
extract it
Code:
tar -zxvf dnscrypt-proxy/dnscrypt-proxy-1.6.0.tar.gz
Code:
cd dnscrypt-proxy-1.6.0
./configure
make
make install
Then run it using
Code:
dnscrypt-proxy --local-address=<IP>:53 -R cisco -d
Where IP is your local IP, and -R cisco means use opendns
see /usr/local/share/dnscrypt-proxy/dnscrypt-resolvers.csv for a list you can use. You can update the list from https://github.com/jedisct1/dnscrypt-proxy/blob/master/dnscrypt-resolvers.csv
Depending on how the rest of your network is configured, you can simply point your main router at your pi to proxy and fetch encrypted dns.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Accuhaler This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The last post was made 10 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 16 - Page Size: 35.03 Kb
