YZ 250 Yamaha 2 stroke casing hole.
cart_man
PostPosted: 09:49 - 09 Nov 2015    Post subject: YZ 250 Yamaha 2 stroke casing hole. Reply with quote
Hi.
I have a YZ 250 2 stroke that is roughly 9 years old. Recently it started leaking oil from the motor casing. So I checked it out and it seems like I have a hole in the lower casing right in front of the front sprocket. It seems like my chain actually chipped away at it even though its nowhere close to it. I spoke to a couple of guys and they said that it is quite common for this to happen and that it is indeed the chain.
My question is HOW? And also how do I fix it?
My understanding is that anything yamaha is seriously expensive stuff never mind the belly of the motor casing Sad
Thanks
dangerousdave
PostPosted: 23:32 - 10 Nov 2015    Post subject: Reply with quote
Best way to repair is to track down another crank case, and replace it as a unit.
There are other options such as using liquid metal, or an alloy weld repair but how effective these would be i would not know. These are a bit of a bodge in my opinion. The alloy weld would require the crankcase to be split anyways so you would be better off just replacing it.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
Pete.
PostPosted: 15:08 - 11 Nov 2015    Post subject: Reply with quote
Put up a photo don't have to take the engine apart should be able to weld it easy.
a.k.a 'Geri'
The last post was made 9 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.86 - MySQL Queries: 16 - Page Size: 37.38 Kb
