ProXimaCore |
ProXimaCore Dougal
Posted: 13:14 - 14 Aug 2004 Post subject: Fuel tap questions. - Closed |
On my bike the fuel tap has 3 settings. Reserve - On - Prime.
If I understand correctly the tap has some sort of vacuum so that no petrol comes out when it's on or reserve without the bike being turned on. Well nothing seems to come out when the tank is disconnected from the hoses.
My question is what is the Prime setting used for? I know when it's set to this a small flow of petrol is released. But what situation would you use this for? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing
Robby |
Robby Dirty Old Man
Guest |
Guest Brolly Dolly
ProXimaCore |
ProXimaCore Dougal
Guest |
Guest Brolly Dolly
Posted: 13:53 - 14 Aug 2004 Post subject: |
'Usually' (good disclaimer that ) the tank breather comes from a metal tube somewhere near the top of the underside of the tank. It'll be a long, thin tube that just pokes down the back of the gearbox.
If the petrol tap bolts into the bottom of the tank and there's no fuel pump, you'll have two pipes from it - a thickish one that feeds petrol to (probably) the middle of the carb bank, and a thinner one that operates the diaphragm. This connects to somewhere on the engine side of the carbs - inlet manifold, carb mounting stub or whatever.
I'll have a dig for some pics |
Guest |
Guest Brolly Dolly
ProXimaCore |
ProXimaCore Dougal
Guest |
Guest Brolly Dolly
Posted: 23:57 - 14 Aug 2004 Post subject: |
To save trawling through a load of posts and probably missing something, can you give us a list of your troubles?
Bike, mileage, service history, bits fitted/removed (air filters, cans etc), nature of problems, what you've tried so far. The more info the better, let's try and sort it. |
ProXimaCore |
ProXimaCore Dougal
Guest |
Guest Brolly Dolly
Posted: 09:37 - 15 Aug 2004 Post subject: |
ProXimaCore wrote: |
The starter wont turn over as I've ran the battery flat from trying and don't have a charger at hand just now. The battery is making a very weird rapid clicking sound though when I press the starter button. Don't know if that's normal of a flat battery or not though. Sounds weird. |
Sounds like the starter solenoid is chattering, classic sign of a low battery. When you thumb the starter button it energises a coil in the solenoid which close two big contacts to power the starter motor. The motor drags so much power it drops the battery volts, and if the battery is low it'll suck enough juice so that there's not enough left to keep the coil energised, so it drops the contacts open again. This cuts the supply to the motor and now means there's enough juice to re-power the coil so if you've still got the button pressed it tries to close the contacts again. The motor sucks the volts down, the coil drops off and the contacts open again. You're effectively switching it on and off rapidly. A fully charged battery is the only answer.
ProXimaCore wrote: | It will run for maybe 5 minutes while having an enormous flat spot that goes from 4krpm to 6krpm. Then gradually the revs will die down more and more till the bike just stalls. Then it wont start for a few hours again and just does the same as before. |
Could be a number of things alas. First thing I'd check, as you've no history, is the valve clearances. If they're tight then when the engine warms up they'll hold a valve or two open and the engine will struggle and eventually die.
4-5000 revs is about where it should come onto the main jets. A lot of bikes have a flat spot around here as standard, it's 'built in' to pass noise tests. The tests say that the bike should be driven past the noise meter at so many revs and then accelerated away - if you build a flat spot in there then it won't scream away and it'll pass the test.
But you say 'enormous'. Has someone been fiddling with the carbs and fitted bigger jets to compensate for the race can? Setting carbs up is quite an art, more so on a little screamer like that, I reckon they need a careful strip down and thorough check over - not a job for the faint hearted. Alternatively, do you have a standard can you could try on to see if it makes it better? Maybe the carbs haven't been fiddle with and they need it to match the race can.
ProXimaCore wrote: | First thing would be the oil. Bike was running fine. But it's drinking 3 litres of oil in a couple of months. It was getting very low and it seemed to be responding funny. So I topped it up and it was fine for a couple of weeks. I now however have noticed that I've put too much in it and I have now corrected that today. So could have maybe damaged something from having not enough and also having too much. |
I remember this now. That is way too much oil usage unless you're doing mega-miles and as it's not running right I guess you're not. It's got to be going somewhere - if it's not leaking out the bottom it's getting pumped into the air filter box or being burnt - you should see some evidence of this: white smoke out the exhaust or heavily carbonned up sparks plugs
Too little oil and you can wreck the engine. Too much and it should pump it out the breather pipe, if it can't then it would pressurise the cases and pop an oil seal or a gasket.
ProXimaCore wrote: | I've changed the spark plugs yesterday. The old ones looked ok. Only a little dirty on the tips. |
That sounds ok
You need a fully charged battery before anything else. Don't whack it on a car charger flat out for an hour, that'll knacker it. Best to get an Optimate type charger and let it brew up slowly, and that'll help keep it good if you connect it every time you park up for the night.
Check the valve clearances and if possible get a compression check done, any reasonable garage should be able to do that for you. That will tell you if you've got serious problems in the cylinders - worn/broken rings or sticking valves, head gasket troubles etc.
If you've got good compression, a healthy battery and a nice spark then you're looking at the carbs but the other bits are easier to check first.
Good luck. |
Kickstart |
Kickstart The Oracle
Posted: 13:32 - 15 Aug 2004 Post subject: |
As mentioned the noise from the starter relay is normal when the battery is flat.
Also note that the bike needs a reasonable amount of power (either from the battery or from the charging system) to run. If you charging system isn't working then the bike will die (or with some charging systems they only click into charging mode when the engine has been revved past a certain point, but only really had this on cars).
While many bikes do have an engineered flat spot at half peak revs (for the noise tests), your bike is (from memory) a GSXR400 which revs fairly high and so 4000~5000 would be well under the point of the flat spot. With CV carbs the fueling at that point will be controlled by the needle jet.
In addition to the point Guest has mentioned I would also suggest that you check that fuel is getting through to the carbs. If the breather pipe for the fuel tank is blocked / kinked then fuel cannot leave the tank to go to the carbs. Try getting the bike to run then open the fuel cap and see if it then idles. Also try starting the bike with the fuel tap on prime (this way you have eliminated the vacuum pipe and the breather pipe).
If you had the pipes connected the wrong way round then you would have just filled the engine with petrol and it is unlikely the bike would run at all.
ProXimaCore |
ProXimaCore Dougal
Posted: 13:54 - 15 Aug 2004 Post subject: |
Oh I forgot to mention one other thing. Possibly important.
I've had problems with the spark plug leads as they aren't sealed and were leaking in water. Causing the bike to act funny and struggling up through the revs a little like I've described above when it rained. The last time the bike did work properly was before the last outing in a heavy downpour. Since then it hasn't been the same. When this happened before, the bike always righted itself after a day or so when it had dried up. But the next day I went out with the bike I had to bump start it for the first time. Each time I wanted to start the bike from there it took a bigger effort at starting. All the above problems then followed.
Don't know if that's relevant but probably worth sharing. Can't believe I forgot about that bit.
On top of all this the rear shock has lost all dampening too. I have got a spare one but that's all going to have to wait. Not having much luck lately. Everything ran so well for months too. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing |
Guest |
Guest Brolly Dolly
Git |
Git Brolly Dolly
ProXimaCore |
ProXimaCore Dougal
Posted: 19:49 - 19 Aug 2004 Post subject: |
Right, finally back on to fixing this thing. (cheers for help so far guys.)
I finally got the battery charger back and charged the battery. The battery is very healthy now and has been for a few days so it looks like that's ok.
Just tried bump starting the thing. It seems to start to work then starts to shake the bike with big vibrations as it fails. So I'm stuck once more. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing |
Guest |
Guest Brolly Dolly
ProXimaCore |
ProXimaCore Dougal
Posted: 20:28 - 19 Aug 2004 Post subject: |
ProXimaCore |
ProXimaCore Dougal
Posted: 21:46 - 30 Aug 2004 Post subject: |
Just to close this off. I got the bike working tonight. As I originally suspected, the vacuum hose had come out of place. The connector had worked it's way loose from the carbs.
Thanks again for everyone that gave advice. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing |
The last post was made 19 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
