Triumph sprint - remnant of retaining pin stuck in caliper
SteveSmith
PostPosted: 19:42 - 14 Nov 2015    Post subject: Triumph sprint - remnant of retaining pin stuck in caliper Reply with quote
https://goo.gl/photos/ijtp6FV4arBBTfb18https://goo.gl/photos/ijtp6FV4arBBTfb18I started out to change my front pads yesterday, but couldn't get the pad retaining pin out because the allen head on it was knackered. I've spent most of the day trying various ways to get it out, including bolt extractors, cutting a slot in it to use a screwdriver, turning it with pliers and drilling it out. In the process I've cut most of it off, so I'm now left with just the threaded part, about 10mm of it, buried inside the caliper (see photos).
Without getting it out, I can't put a new one in, which means I've no way of fixing pads into the caliper. I'm looking at £400 for a new caliper. Can anyone offer any ideas for getting it out, or recommend anywhere in Bristol that might be able to drill it out and put a new thread in if I took the caliper to them?
Thanks,
Steve.
Busa1340R
PostPosted: 23:19 - 14 Nov 2015    Post subject: Reply with quote
You could give Colin at C&B a try.......
https://www.yate-engines.net/40024/info.php?p=8&pno=0
I think it's fair to say that you've mangled that a bit though....don't expect him to look too excited about that job Neutral
Or, how's about..........https://www.ebay.co.uk/sch/i.html?geo_id=32251&MT_ID=12&crlp=78298696380_847&rlsatarget=kwd-535199383&keyword=front+caliper&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F710-35649-5910-0%252F2%253Fmpre%253Dhttp%25253A%25252F%25252Fwww.ebay.co.uk%25252Fulk%25252Fsch%25252F%25253F_nkw%25253Dfront%25252520caliper%2526keyword%253Dfront%252520caliper%2526crlp%253D78298696380_847%2526MT_ID%253D12%2526geo_id%253D32251%2526rlsatarget%253Dkwd-535199383%2526adpos%253D1t1%2526device%253Dt%2526loc%253D9045640%2526poi%253D1006567%2526treatment_id%253D7%2526srcrot%253D710-35649-5910-0%2526rvr_id%253D929999197991&clk_rvr_id=929999197991&treatment_id=7&_odkw=front+caliper&poi=1006567&adpos=1t1&ul_noapp=true&device=t&crdt=0&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=triumph+sprint+front+caliper&_sacat=0
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
andys675
PostPosted: 23:52 - 14 Nov 2015    Post subject: Reply with quote
mine were like that on a CB350S I bought to rebuild
I tapped a small chisel into the middle of the remaining threaded bit and then twisted the chisel with some mole grips and they came out Thumbs Up
PostPosted: 13:10 - 15 Nov 2015    Post subject: Reply with quote
I'd be drilling it all the way through. At some point, it'll break loose and unscrew. often does so as the drill "bites" on the last couple of mm.
I'm not sure how you'll get on centring it though. With it being that mangled and what looks like an off-centre pilot hole. I'd probably go right in there with a 4 or 4.5mm bit if you are confident you can get it right down the middle. Just do it slowly this time, with lots of lube and coolant on the bit!
If you get the hole all the way through, it'll likely unscrew itself anyway or you may be able to collapse the remains into the centre of the hole then run a tap along it to clean the threads up.
The last post was made 10 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.31 - MySQL Queries: 14 - Page Size: 43.14 Kb
