| Snop Doog |
 Snop Doog Brolly Dolly
| Robby |
 Robby Dirty Old Man
| Snop Doog |
| Robby |
 Robby Dirty Old Man
| Snop Doog |
| Ariel Badger |
 Ariel Badger Super Spammer
| Snop Doog |
| Snod Blatter |
 Snod Blatter Crazy Courier
| Snop Doog |
 Posted: 23:46 - 07 Dec 2015 Post subject: |
Got it sorted today - £20
Turned out I hadn't cleaned the pistons & slider pins enough. The slider pins had seized too.
I don't think I'll be touching the brakes again myself anyway, far too dangerous. |
| Robby |
 Robby Dirty Old Man
 Posted: 08:56 - 08 Dec 2015 Post subject: |
Just learn to do the job properly.
Typically you can only get away with just a pad change two out of three times. Often you will also need to do one or more or the following:
1. Clean all sliding pins, properly clean the caliper.
2. Replace sliding pins.
3. Clean piston (basic clean).
4. Remove piston and seals, scrape out corrosion, remove some corrosion from piston with a finishing pad or light emery paper.
5. Replace piston and seals.
If I'm doing my first brake job on a new to me bike, the caliper will get the works - strip down, remove seals, scrape out corrosion, smooth down piston, new sliding pins, reassemble with new grease in some places and new brake fluid.
Learn to do the full job, then you'll know what needs doing next time you change the pads. Replacing the pads and sliding pins, doing a full clean and replacing the brake fluid is still cheaper than taking it to a shop just to get the pads changed. |
| skatefreak |
 skatefreak World Chat Champion
| misscrabstick |
 misscrabstick Crazy Courier
| Rogerborg |
 Rogerborg nimbA
| c_dug |
 c_dug Super Spammer
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
