tank
paintpot
PostPosted: 18:09 - 06 Dec 2015    Post subject: tank Reply with quote
ok i bought a harley tank,im going to weld the holes up,the big question is,will this gas tap work,and were to weld it.pics
https://i864.photobucket.com/albums/ab207/PAINTPOTS/CUSTOM%20PAINT/atank_zpspmmeyqvz.png
https://i864.photobucket.com/albums/ab207/PAINTPOTS/CUSTOM%20PAINT/tap_zpszfcrdgru.png many thanks
paintpot
A100man
PostPosted: 14:49 - 07 Dec 2015    Post subject: Reply with quote
I'd buy one made for a bike, (if possible with a reserve postion) so you can be reasonably sure it will flow enough fuel.
Positon it as close as possible to the lowest part of teh tank - don't want 'dead spot' to gather cr@p and condensed water. Make sure you have clearance fo rth internal filter/reserve tube.
PostPosted: 16:48 - 07 Dec 2015    Post subject: Reply with quote
If I were you, I'd make up a steel plate to fit over that rectangular hole with all the perimeter holes (cardboard template would be easiest).
In the middle of that flange/plate, I'd weld/braze/silver solder a 1/4" BSP socket then drill up the middle.
I'd then fit it to the tank using a cardboard gasket and a skimming of RTV.
Next I would buy neither of those fuel taps because they don't have a reserve position. Instead I'd get a standard motorcycle 1/4" BSP male fuel cock with a reserve position and fit that.
You can also get female fitting fuel cocks. So you could use one of those and fit a 1/4" equal nipple to your flange. fnar
Really nice (but pricey) one here:
https://www.hitchcocksmotorcycles.com/amal-carburettors-petrol-taps-fittings#part_5034
Cheaper ones on ebay.
paintpot
PostPosted: 20:34 - 07 Dec 2015    Post subject: Reply with quote
Many thanks for your help
paintpot
The last post was made 10 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 14 - Page Size: 40.48 Kb
