| stevo as b4 |
| WD Forte |
 WD Forte World Chat Champion
| stevo as b4 |
| WD Forte |
 Posted: 00:26 - 06 Dec 2015 Post subject: |
Ignitech do various programmable ignition units
that many guys with older CDI igntion CXs fitted
as changing stators meant an engine drop and the unique ( to the CX) CDI boxes were getting scarce.
and could fail with no warning
( I have the later, better TI system in mine)
Have a look but personally I wouldn't bother on a simple to fix bike like that
You could rewind the stator and source coils yourself quite easily and 1 cyl CDI boxes are cheap and easy to get hold of as many bikes use them.
The Sparker DC-CDI and DC-CDI-P ( programmable) are for 1 cyl machines
https://www.ignitech.cz/en/vyrobky ____________________ bikers smell of wee |
| Robby |
 Robby Dirty Old Man
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| stevo as b4 |
 Posted: 16:30 - 06 Dec 2015 Post subject: |
All good questions, will try to answer if I can.
1, Yeah it's only a 124cc, not that I see that as an issue really
2, Your right that my bike runs a mechanically driven power valve, so all the CDI needs to do is tell the plug when to spark for the appropriate engine speed.
3, Not even RGV250's gain masses of extra bhp at peak from a fully pogramable 2D or 3D ignition. You'd be lucky to get 2-3bhp more on those bikes, but the midrange increase is significant and so is the benefit of accurate adjustable power valve control at different speeds to what the factory CDI was pre-set to.
I have a load of new parts soon to be fitted to my KMX125, stuff like a bigger carb, reedblock, modified airbox lid, and a pipe as well. The new pipe will be a one off pipe that is custom built to suit the tune of the std engine.
The pipe builder needed a full ignition timing map from 1000-10000rpm, to get the data for the best possible pipe design. I could not supply this info despite enquiry's to KHI japan, and because I'm paying a lot of money for the pipe, I didn't want the design to be compromised for the sake of an ignition system
The new CDI will allow a custom ignition map to be made on the dyno to make the pipe work at it's best and give the most performance possible.
Lastly I have a re-conditioned 200cc big bore top end sat here that's been ported and had the head modified too, if the CDI does not do much on the 125cc, it will probably be more effective on the tuned 200cc kit when that goes on eventually. Obviously my new pipe will be useless then, but I'd like to do this in stages and run the bike as a 125 with all the aftermarket bits on first to see what it's like.
Anyway I'm surprised you ask why I'd like a new CDI, as your already aware even your X5 would probably gain something worthwhile from a programmable ignition, especially if you have non std pipes or any other mods fitted? |
| redeem ouzzer |
| stevo as b4 |
 Posted: 00:34 - 07 Dec 2015 Post subject: |
The thing is that Id actually pay extra to have a mechanically driven power valve system on a two stroke bike. If it opens and closes at roughly the right rpm, then that's all it needs to do, and it's bloody simple and hard for it to spaz up and go wrong.
I think progressive power valve systems are a step too far on two strokes anyway. All you need is the bottom end boost from a power valve, and at the rpm point where the graphs from an open and closed power valve cross over, for it to open etc.
It does depend on what type of powervalve system is used too, but I think the RD350F would have been more exiting if it was a system where it snapped open and closed at a certain rpm, instead of a progressive opening?
I know I could save a lot of time and money if I forget about ignitions and tuning, but I'm committed to having my pipe built now and I've spent a load on a bike so far that I want to be buried with, as I'll never sell it for sentimental reasons.
I could take a leaf out of Carvel's book, and if some fool was stupid enough to buy all my KMX's engines, parts and spares, id have enough for an immaculate 98/99 Fireblade instead of messing with teenagers bikes.
The trouble is I guarantee that if I had a mint 98 Blade instead, id ride it no more often than the KMX, and it would be just another Sunday polishing bike more often than not, but without the nostalgia I get from my current bike. |
| redeem ouzzer |
| stevo as b4 |
| stevo as b4 |
| Islander |
 Islander World Chat Champion
 Posted: 15:18 - 11 Dec 2015 Post subject: |
| WD Forte wrote: | Ignitech do various programmable ignition units
https://www.ignitech.cz/en/vyrobky |
Ignitech have the worst after sales service. They don't respond to emails and they still haven't replaced/repaired my in-warranty TCIP4 unit. Avoid like the plague. |
The last post was made 10 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
