| Author |
| Radicalshady |
 Radicalshady L Plate Warrior
 Posted: 20:40 - 12 Dec 2015 Post subject: Yamaha r15 power struggle / error code 46 |
New here.. Actually I don't post anything anywhere. . This feels new. And apologies for my bad English.
Well what we have here is a 6 year old Yamaha YZF R15.
It's a 4 valve 150cc single cylinder, liquid cooled, fuel injected motorcycle.
And the problem, I had a head light flickering , ever since I got the new headlights and the whole front portion replaced after a crash. The headlight , is two separate ones for bright and dim in obvious yzf fashion.
Only the dim one flickers, it flickers in the bottom gears, when revved..
When switched to bright.. Both comes on and stays on without any problem or flicker.
Well that's only the beginning of the story.
The flicker was there and the service guys couldn't figure it out or didn't bother.
It stayed like that for a year. And didn't give me any trouble. But I don't know if it was a sign of what was about to come ..
Then one day I felt the starter motor struggling to get the engine running.
Started to ride , after just 2 miles the yellow light onboard started blipping.
I turned off the engine. Tried to restart it.
tuk tuk tuk , instead of smooth starting.
The yellow light kept blipping. Four times slow , six times fast. Sat there on the foot path and searched online..
It said , error code 46. ( I thought Heyy it's the number of Rossi , it can't be that bad)
I looked it up and it said fuel pump not getting enough power or something.
So I turned the ignition on and pressed the horn.. Weak..
Pushed it , started, got back home.
By the next day, the battery was fully drained.
Took the battery out , given it for charging.
The guy at shop asked how old was the battery, I said one year, and he said it's more than four years old , it doesn't get charged, etc. Sweet probably I have been duped by the authorized service guys another time.
Got the new battery, connected it, the bike won't start, the same tuk tuk weak cranking instead of smooth operation.. Again yellow light blipping, error code 46.
Pushed it ,started it.. Rode it.. Rode it like I stole it.. yellow light went off.. Lights are back , self start is back. But feels a bit weak..
One week later, it's dead again.. I've been riding only very rarely In the mean time.. But took it for a longish traffic ploughing in daylight and I could see the symptoms on the way, weak horn ,slightly lesser power etc. On the way back home the error 46 lights are back.. Now the battery is dead.. No lights or console with ignition on.
Push start works.. But some new symptoms I noticed.
The lights work when the push started bike is idling but weak , revving doesn't help, and switching on the park light the rpm falls by 50.. On the dipper it falls further .. Bright, even further ..
There was power loss when switching to bright while riding too..
While idling without any lights the rpm fluctuates now.. Sometime the engine nearly stalls..
Stator, rr? Bad wiring.. I am not really good at this.. But I really love to learn.. Every bit you guys would teach me.. So don't worry about typing long post , you won't bore me.. Also consider me an idiot...
The stator side of the crank case got really hot within just 5 minutes of idling today.
I really don't know if that's how it was or if somethings going to explode if i push it a lil more further..
And another thing is... My new battery is one inch taller than my previous one..The seat fits okay, but I am worried if something could get damaged if I'm putting my weight on it..kindly advise on this too... Cause, a battery exploding under my .... Would be a sorry sight... |
| Back to top |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| Back to top |
| Radicalshady |
| Back to top |
| Radicalshady |
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| Radicalshady |
| Back to top |
| Radicalshady |
| Back to top |
| Polarbear |
 Polarbear Super Spammer
 Posted: 13:42 - 13 Dec 2015 Post subject: |
Honestly, get a multimeter. You can get them as cheap as chips nowadays. As long as they measure AC and DC voltage and continuity (and everyone will) that will be all you need until you become proficient and decide to invest in a decent bit of kit.
It will pay for itself in one job  ____________________ Triumph Trophy Launch Edition |
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
There is a gap of 9 years, 124 days between these two posts... |
| BanglarBike |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 BanglarBike L Plate Warrior
| Back to top |
The last post was made 1 year, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
