Fitting a so called 'ABS' brake lever/master
Sean.S
PostPosted: 23:58 - 28 Dec 2015    Post subject: Fitting a so called 'ABS' brake lever/master Reply with quote
Okay so i need to pick your brains again with another noob question. A master cylinder/brake lever i want to buy is listed on ebay as an ABS lever. My questions are;
-can this be used with a brake thats not ABS?
-is the ABS even operated by the lever?
here is the lever in question
Ichy
PostPosted: 00:10 - 29 Dec 2015    Post subject: Reply with quote
Maybe the master cylinder is different on ABS?
What bike is it for?
Sean.S
PostPosted: 00:25 - 29 Dec 2015    Post subject: Reply with quote
i dont know but hopefully im about to find out Razz if so, then would adding this master cylinder to an older bike, convert its front brake to ABS?
the unit is from a 2013 honda cb500, and would be fitted to a 90s honda crm250
sean
Albigularis
PostPosted: 00:34 - 29 Dec 2015    Post subject: Reply with quote
Usually the ABS unit is a servo which is connected along the lines of the brakes. Certainly on the Multistrada and my R1200GS, the master cylinders were as normal, and the servo is about half way down the brake lines.
Here's an idea of how it works sorta, although its a fairly complex diagram for what its showing-
https://www.motorcycleinfo.co.uk/resources/6795/assets/images/BMW%20R1200GS/hari/GS_models/bmw_r1200gs_abs_2007.jpg
To have ABS, you need wheel speed sensors on the wheels, a sensor connected to the ECU and a pump to loosen the brakes off when you slam them on too hard. Perhaps it just has ABS in the title because it fits an ABS bike?
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Sean.S
PostPosted: 00:41 - 29 Dec 2015    Post subject: Reply with quote
@Albigularis: thanks for that, youve explained everything i needed to know
Sean
wr6133
PostPosted: 06:16 - 29 Dec 2015    Post subject: Reply with quote
https://i1249.photobucket.com/albums/hh504/wr6133/Third-party-facepalm.jpg
Sean.S
PostPosted: 07:48 - 29 Dec 2015    Post subject: Reply with quote
Yes alright thank you Rolling Eyes
i am still learning about bikes and mechanics and there are things i still dont know about, but i do realise now what a dumb question that was. Nevermind
Stalk
PostPosted: 09:24 - 29 Dec 2015    Post subject: Reply with quote
We all ask questions, that's how we learn. Keep asking! Dumb would have been fitting the part and then coming on her saying "Please help, Abs not working"
weasley
PostPosted: 09:28 - 29 Dec 2015    Post subject: Reply with quote
I guess I agree with the the sentiment, but I am a bit alarmed that someone without even a basic grasp of brake functionality is contemplating the replacement of a master cylinder. Brakes are one of the systems where 'trial and error' is not a practical learning strategy.
Sean.S
PostPosted: 10:45 - 29 Dec 2015    Post subject: Reply with quote
I could install and bleed basic brakes competently, but no i didn't understand how abs works. Ive never come across it before, so havent needed to know
Thanks for the responses
MCN
PostPosted: 14:53 - 30 Dec 2015    Post subject: Reply with quote
The pump is the 'actuator' part which puts the brake on.
There are valves which open (when the ABS control dictates via sensor inputs) to release the fluid pressure and the braking effect is lost.
The last post was made 10 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 14 - Page Size: 68.77 Kb
