Another plumbing question
PostPosted: 20:44 - 10 Jan 2016    Post subject: Another plumbing question Reply with quote
At the risk of turning this into PCF...
There is water right up to the the bottom of the plug in my bath, is this right? I've never seen that before.
I pulled the cover off to have a look and the waste drops down for the then rises to meet up with the main waste pipe. I can't see how it would drain all the way. I've tried a rod, drain unblocker and plunger it hasn't made a difference.
Possibly related the washing machine plumbed in the kitchen is making gargling noises periodically when on. Something wrong with my waste maybe?
stephen_o
PostPosted: 00:09 - 12 Jan 2016    Post subject: Reply with quote
water won't flow uphill but can seep through capilary action, its likely that the pipe is slightly blocked with debris and combined with the gradient is enough to stop the water flowing. Take the pipes apart and clear out providing not solvent welded. Only adjusting the height so there is a fall from the bottom of the bath and washer to the drain will solve it long term. if its not possible to adjust the drain height then consider a saniflo unit to pump the waste uphill.
current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf
The last post was made 10 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 31.9 Kb
