Ear plugs - recommendations....
CKBear
PostPosted: 16:04 - 16 Feb 2016    Post subject: Ear plugs - recommendations.... Reply with quote
Hello all!
I was wondering if you knowledgeable guys and ladies had any recommendations for ear plugs. I tried cheap ones and they hurt like hell!
Thanks Smile
DrDonnyBrago
PostPosted: 16:23 - 16 Feb 2016    Post subject: Reply with quote
I can't wear reusable plugs without it feeling like my eardrums are being damaged every time they go in/out.
I use 3M 1100 disposables. I get a week or two out of each pair, buy in bulk on ebay for about 10p a pair. Dump them when they are dirty or they have lost their "memory foaminess".
waffles
PostPosted: 16:27 - 16 Feb 2016    Post subject: Reply with quote
What is your budget?
When you say cheap ones, I presume you mean the foam jobs that you roll up and they expand slightly in your ears? I would definitely recommend moulded ear plugs from now on. I had some moulds made at one of the bike shows by Ultimate and the guy ran through many options with me (colours, separate plugs or headphone versions) before I settled on the ones I liked. They arrived a couple of weeks later in a little zip up case. Cons - expensive. Pros - swift turnaround, aftersales care is fab, takes into account the stupid piercings I have in my ears so they modified my plugs and I have a full shell for one ear and a half shell for the other.
There are home kits you can do yourself for much less money like this one on Amazon. But it is a similar deal. Mix stuff together, put in ears, allow to set, Bob's your uncle! Several people on here have made their own and should be able to give you a bit more information about how they work out.
But give moulded plus some serious consideration, either go with a company or do it yourself but I think you will be much happier with something custom made for your ears Thumbs Up
DrDonnyBrago
PostPosted: 16:50 - 16 Feb 2016    Post subject: Reply with quote
By "reusable" ear drum poppers I should qualify that I mean the "Stielhandgranate" shaped pieces of rubber, not the moulded to your ear silicone type.
Matt B
PostPosted: 16:53 - 16 Feb 2016    Post subject: Reply with quote
https://freemarket.kiev.ua/images_message/2400/216311/808326/1710585.jpg
Moldex Spark Plugs, about £7 for 50 pairs on ebay. They are shaped and soft so they feel nicer inside the ear. Decent 35dB noise attenuation - that's more than a lot of other foam plugs. Disposable but they do last a few uses before needing to be binned.
groovylee
PostPosted: 16:57 - 16 Feb 2016    Post subject: Reply with quote
i bought one of the DIY kits for about £7
they are a bit of a faff, but i managed to get a good set of normal ones, and then a set with my headphones moulded in.
tbh, i find the normal set i made to be a bit too airtight, and they make me feel a bit ill. i use the headphone ones a lot though, and theyre great.
I would seriously consider getting some pro ones made and having headphone ones done. Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
PostPosted: 17:10 - 16 Feb 2016    Post subject: Reply with quote
£2.94 delivered.
Mix, put in ears, wait, remove done.
16g is enough for two pairs, or one pair and glooping over a pair of ear-buds for playing bangin choons.
ScaredyCat
PostPosted: 17:44 - 16 Feb 2016    Post subject: Reply with quote
I got a box of 200 (individually wrapped) 3m EarSoft FX for 24 quids with free delivery, arrived in 2 days...
Tried others but they don't seem as good to me.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
-Matt-
PostPosted: 17:48 - 16 Feb 2016    Post subject: Reply with quote
Found these Howard Leight ear plugs are good and pretty cheap. (May be cheaper sellers than the link).
bamt
PostPosted: 18:37 - 16 Feb 2016    Post subject: Reply with quote
I use the same, though normally bought off eBay. I mark the one I'm putting in my left ear with a marker so they always go in the same ones, and replace at least once a week as they lose their effectiveness.
Icon
PostPosted: 19:10 - 16 Feb 2016    Post subject: Reply with quote
I got a pack (3 pairs) of these foam ear plugs a year ago. I'm still using them and they weren't expensive. They're easy to wash with warm water, very comfortable and still work well (35dB). I can wear them for 10 hours a day no problem. I honestly don't why you would bother buying a 200 pack of cheap uncomfortable earplugs when you could just buy these.
https://www.quies.com/product/foam-earplugs/
Llama-Farmer
PostPosted: 19:23 - 16 Feb 2016    Post subject: Reply with quote
I use the same, they're the only foam ones that I can use which stay in my ears and don't get uncomfortable, even after hours.
Can't fault any of the 3M products tbh, I have some 3M Peltor X4A ear defenders in my garage that I use for noisy times such as when I've got the air compressor running, or the bike running, or using angle grinders/chain saws/hedge trimmer etc.
And got some Peltor X5As that I bought myself for use at work rather than the ones they provided... much more comfortable, lighter, and block out more noise.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
ScaredyCat
PostPosted: 19:57 - 16 Feb 2016    Post subject: Reply with quote
I only use them for a couple of days, usually because I drop one or they get too warmed up while I'm putting them in and wont compress. Also have the added bonus of occasionally getting 3 in one bag Smile
Interesting point about the marker though. I've never done that but might give it a go.
Bigvern72
PostPosted: 20:26 - 16 Feb 2016    Post subject: Reply with quote
I use these too.....and get them free from work ;@)
Tracer 700 (66) and Triumph America (65) - current rides
Yamaha xj600 diversion and Honda cb125f (65) - both 'retired'
Llama-Farmer
PostPosted: 21:00 - 16 Feb 2016    Post subject: Reply with quote
If you intend to reuse them it is worthwhile, not uncommon to develop outer ear infections by transferring bacteria from one ear canal to the other.
BTTD
PostPosted: 23:41 - 16 Feb 2016    Post subject: Reply with quote
I've used Howard Leight foam earplugs. They fit my ears well and felt comfortable.
At the moment I'm using some rubber earplugs with a filter in the middle. The idea is to cut out louder noise while allowing you to hear the quieter normal stuff.
Used these ones
https://www.amazon.co.uk/gp/aw/d/B00MIQ4O7Y/ref=aw_st_pd_dx_bx_2?ie=UTF8&dpID=51tQrCfaCEL&dpSrc=sims&preST=_SL500_SR100%2C69_&refRID=NN1A7CMBG5R64ZB1QWKH
And these ones
https://www.amazon.co.uk/gp/product/B00D8F550O/ref=ya_st_dp_summary
I've started using the second ones today, think I prefer the first ones though. The first ones just seem to be a nicer plug with a better seal in my ear. They also seem to let more normal level sound through while cutting the same amount of wind noise.
Matt B
PostPosted: 12:56 - 17 Feb 2016    Post subject: Reply with quote
A few of you seem to be using them happily so I've ordered 10 pairs of the Howard Leight plugs for a few ponds to compare with the Moldex ones Thumbs Up
talkToTheHat
PostPosted: 05:09 - 18 Feb 2016    Post subject: Reply with quote
You can get selection packs on ebay and amazon. Tried everything, nothing disposable much better than sparkplugs, but that's my preference. I like disposables. I'd much rather shrug and get a spare set out from under my seat than try to clean a dropped reusable one.
I used to use musician's ear plugs when doing anyhing at playing with a drummer volume, or indeed playing drums. Was always annoying if one came out on a filthy stage. They were moulded and pricey, really balanced sound. Don't need that on a bike. Disposables take a lot of the top end off the sound, so make bikes sound much beefier.
Bandit. does. everything.
bamt
PostPosted: 10:18 - 18 Feb 2016    Post subject: Reply with quote
I used musician's re-usable ones for a while, but as you say they really aren't optimised for on the bike. Disposables protected my ears (as in noticeably quieter and less temporary hearing loss on longer rides) better.
I carry a spare set in my jacket, under my seat and in my desk at work. If they get wet they can lose their sponginess, so I don't even attempt to clean them any more than brushing lose debris from them. I have a thick resealable bag in my jacket (a small metallised anti-static bag for components) that I put them in as soon as they come out of my ears.
JasmineJasmin... This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
inline4
PostPosted: 12:37 - 18 Feb 2016    Post subject: Reply with quote
I've tried different variants of Moldex ear plugs and they are ok but I think Macks ear plugs are a little better.
The Macks ones are a touch (pennies) more expensive.
CKBear
PostPosted: 12:46 - 18 Feb 2016    Post subject: Thanks for the feedback Reply with quote
Cheers all. I will have a look at various options. I kinda dont fancy going deaf Smile
Tierbirdy
PostPosted: 13:02 - 18 Feb 2016    Post subject: Reply with quote
Cheapish JVC XXtreme "noise cancelling" in-ear headphones connected to iphone tucked inside jacket pocket, decent-ish protection from road noise and can have a little bit of helmet karaoke to keep me entertained on long boring motorway rides.
Theres probably reasons why thats a bad idea but oh well.
thepuma
PostPosted: 13:48 - 18 Feb 2016    Post subject: Reply with quote
I wear the pinlock ones and they are really good.
765 RS
recman
PostPosted: 22:28 - 18 Feb 2016    Post subject: Reply with quote
3M E-A-R Classics for me, very good expansion and noise blocking.
I can't get on with the tapered type, they fall out way too easily.
The last post was made 10 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 130.2 Kb
