| Macjoyrider |
 Macjoyrider Derestricted Danger
| Itchy |
 Itchy Super Spammer
 Posted: 21:14 - 14 Jan 2016 Post subject: |
A left field suggestion is the starter relay.
On Hondas they tend to rot causing funny electrical gremlins that will result in erratic running.
Look for a big wire off the battery and check the relay itself if it's oozing green copper liquid... it be dead.
Two of my old Hondas had this problem. I tore the bikes apart to find out what it was. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| mudcow007 |
 mudcow007 World Chat Champion
| Macjoyrider |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Macjoyrider |
| redeem ouzzer |
| temeluchus |
| Macjoyrider |
 Posted: 09:16 - 15 Jan 2016 Post subject: |
Right, I have looked at a few photos of my carbs and it seems to me that when you put the emulsion tube into the internal passage, it will be separated from the needle by a round metal seat. That seat is in direct contact with the needle. Surely that would be the first thing to wear, wouldnt it? And that seat, I dont think is removable  |
| camcam |
 camcam Trackday Trickster
| chris-red |
| Fizzer Thou |
 Posted: 14:25 - 21 Jan 2016 Post subject: |
I cannot see why it would be the starter relay when the OPs initial comments were about the bike running at low revs,not about having problems starting the engine
I would be looking at the spark plug caps and the end of the leads where the caps screw into place.I have had several problems where the caps have had a slight crack in them and the spark energy from the coil has jumped to the engine casing.The resistance of each plug cap should be between 5,000 to 10,000 ohms.
Also,check that the green earth cable to the coil bracket is clean and not corroded. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| chris-red |
| Vincent |
 Vincent Banned
| Macjoyrider |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Macjoyrider |
| Snowdonia Rider |
 Snowdonia Rider World Chat Champion
 Posted: 08:49 - 09 Feb 2016 Post subject: |
My bike had this problem due to a lead starting to come away from the spark plug cap, with that sorted it cured erratic idling. But seeing as you've already done that :hmm: ____________________ I want your clothes, your boots and your motorcycle.
My YouTube channel: https://www.youtube.com/c/SnowdoniaRider |
| Macjoyrider |
 Posted: 21:28 - 10 Feb 2016 Post subject: |
Right, applying logic to my problem: problem with my idle can be caused by low compression, issue with fuel/air mix, or ignition.
I had the compression tested a while ago and it was near enough perfect. I don't remember the actual results but they were high and consistent. So the compression is not an issue.
Fuel/air mix:
- vacuum leak- having stripped the carbs apart about 20 times, I have examined all intake boots and seen no cracks or holes. I sprayed carb cleaner all over the intakes, carbs and air box but there was no change in idle speed. I can safely assume there is no leak.
- clogged pilot jet- I have cleaned the carbs thoroughly a few times and once had it ultrasonically cleaned. No effect on rough idle
- fuel leak through the emulsion tube- having bought another carburetor, which has been rebuilt using dynojet and lower mileage, there has been no improvement.
- mixture screw- played with those a lot and no matter what settings, the idle still plays up.
- other carb components- upon visual inspection, there was nothing of concern. Diaphragms are fine and sliders work properly. Choke works smoothly.
-fuel supply- the fuel is flowing and the petcock works fine.
I dont think there is anything else I can blame here.
Ignition:
- battery, alternator and regulator- all in good order. Battery and reg have been replaced. Battery is charging.
-coils and leads- replaced all to no effect
- starter relay- replaced... no effect
-TPS-tested and works fine.
- plugs- I bought new ones last year but now I am thinking thei might have been faulty. I just order new iridium plugs and see if they make a difference.
If the plugs dont make it then I am stuck but having gone through the above, I am led to think it might be sth to do with the elctrical system. Anyone has any ideas as to what I should test? Have I missed anything? |
| iooi |
 iooi Super Spammer
 Posted: 13:10 - 11 Feb 2016 Post subject: |
See below...  ____________________ Just because my bike was A DIVVY, does not mean i am......
| iooi |
 iooi Super Spammer
| bugeye_bob |
 bugeye_bob World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 19:44 - 11 Feb 2016 Post subject: |
| Macjoyrider wrote: | Right, applying logic to my problem: problem with my idle can be caused by low compression, issue with fuel/air mix, or ignition.
Fuel/air mix:
Ignition:
It's a voodoo bike, has to be. Get shot of it.
But what about the ignitor/CDI/TCI or WHY.. Tried a substitute for elimination purposes ? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Macjoyrider |
| mudcow007 |
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
