Battery will just not hold charge!!!!
oliverpetrie
PostPosted: 19:21 - 28 Feb 2016    Post subject: Battery will just not hold charge!!!! Reply with quote
So I made a post a month ago about my Peugeot Speedfight 3 50cc not moving. The dilemma was that the pilot jets were too small, and not allowing enough fuel in meaning the bike wouldnt take off. This has been fixed now Razz
However!
When we bought the bike we got it home, started it and thought that the battery had just lost its charge. We bought a new battery and thought nothing of it. Bam. The battery lost charge in a matter of hours. We took it into the "bike medic" and which he changed the rectifier/regulator and told us that the flywheel and the stator needed changing, which we did ourselves. After removing the old flywheel and stator (which the copper wires inside were split) we put the new one back in and fired it up. The charge on this lasted a couple of days, so we took the battery back and got a new one.
TL;DR
With the battery being fully charged, it has lasted about 7 days before dying, which is quite strange. We have replaced everything with new parts on the battery end (new battery, new rectifier/regulator, new flywheel and a new stator) but we can't just figure out what it could be! Any helpful tips and suggestions are welcome as I should have been out on the road a while back but the battery dilemma has prevented me from being out Crying or Very sad
Many thanks, Oliver
PostPosted: 19:55 - 28 Feb 2016    Post subject: Re: Battery will just not hold charge!!!! Reply with quote
oliverpetrie wrote:
Battery fucked
Have you checked the level of water in the battery? YOu can buy distilled (de-ionised) water for about £2
Triumph Sprint ST 1050
CaNsA
PostPosted: 19:56 - 28 Feb 2016    Post subject: Re: Battery will just not hold charge!!!! Reply with quote
oliverpetrie wrote:
You need more atleast 300 more "!", that'll sort it.
PostPosted: 19:59 - 28 Feb 2016    Post subject: Reply with quote
All this time and money you've put in, did it include 5 minutes with a £5 multimeter?
What are your battery voltage readings cold, and with the engine idling, and revving?
oliverpetrie
PostPosted: 21:26 - 28 Feb 2016    Post subject: Re: Battery will just not hold charge!!!! Reply with quote
Yeah, the battery is full with the fluid it came with
oliverpetrie
PostPosted: 21:27 - 28 Feb 2016    Post subject: Reply with quote
We've measured the voltages and it's about right, Dad is an electrician so thats a bonus...
PostPosted: 21:39 - 28 Feb 2016    Post subject: Reply with quote
An auto electrician? Or a domestic one? I wouldn't necessarily expect the latter to know much about the vageries of motorcycle charging systems. Most motorcycle mechanics are pretty sketchy on it.
When you say it's not holding a charge for 7 days. Is the bike being used in that time?
If it's standing doing nothing and the battery is going flat, you have a current leakage problem.
If it's being ridden in that time, you have a charging system problem.
PostPosted: 21:41 - 28 Feb 2016    Post subject: Reply with quote
Ask your Dad how many volts it was when revved.
Not saying your Dad isn't cool but some electricians can be right nobby-knowalls.
Undinist
PostPosted: 22:38 - 28 Feb 2016    Post subject: Reply with quote
These questions need answering.
Also, how old is the bike and is there any corrosion on it?
oliverpetrie
PostPosted: 00:12 - 29 Feb 2016    Post subject: Reply with quote
[quote="Undinist"]
The bike was used 2 out of 7 of those days, the rest it was sat there doing nothing
oliverpetrie
PostPosted: 00:13 - 29 Feb 2016    Post subject: Reply with quote
If I remember it was about 11-12v
oliverpetrie
PostPosted: 00:14 - 29 Feb 2016    Post subject: Reply with quote
The bike is a 12 reg and is 4 years old, no corrosion either
Carvel
PostPosted: 00:25 - 29 Feb 2016    Post subject: Reply with quote
So it isn't charging, you should be seeing more than that on a stand alone fully charged battery.
oliverpetrie
PostPosted: 00:53 - 29 Feb 2016    Post subject: Reply with quote
Well the battery goes onto the bike fully charged, the stator and regulator rectifier has been changed too, so all things are working, its just a case of what isnt working...
smallfrowne
PostPosted: 11:35 - 29 Feb 2016    Post subject: Reply with quote
Well, have you checked the AC output of the stator? You can do that with the stator unplugged, bike running. Do any connections look all melty or coroded? I had a bike whos stator connections felt very warm due to the corrosion of the pins, and that bike was very poorly electrical wise, it didn't charge and ate its rectifiers for brekky.
If it's only showing 11-12V with a few revs on then it isn't charging, needs to be up nearer 13.5-14V.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
iooi
PostPosted: 14:54 - 29 Feb 2016    Post subject: Reply with quote
So forget that and come back with some real figures.
V when not running
V when running Thumbs Up
Does the bike have a alarm or anything like that?
oliverpetrie
PostPosted: 21:45 - 29 Feb 2016    Post subject: Reply with quote
Nah nothing apart from a Car Lighter socket under the seat?
PostPosted: 22:41 - 29 Feb 2016    Post subject: Reply with quote
Do you leave anything attached to it when the bike is parked?
andys675
PostPosted: 23:12 - 29 Feb 2016    Post subject: Reply with quote
cheap chinky battery? not conditioned
talkToTheHat
PostPosted: 04:41 - 01 Mar 2016    Post subject: Reply with quote
There's not a cheap and nasty alarm on the bike is there?
Bandit. does. everything.
Andy_Pagin
PostPosted: 09:13 - 01 Mar 2016    Post subject: Reply with quote
^ Is always the way to start diagnosing battery problems, there's not much point posting here until you have these figures.
iooi
PostPosted: 10:08 - 01 Mar 2016    Post subject: Reply with quote
Through a relay or direct to the battery? Is it fused?
oliverpetrie
PostPosted: 20:55 - 01 Mar 2016    Post subject: Reply with quote
Okay so I went into my shed and measured the voltages and whatnot, and it read;
Battery without bike on - 12.5v
Battery with bike on (engine not on) - 11.8v
Battery with bike on (engine on) - 11.6-11.8v
Battery with bike on (engine on and revving) -11.8-11.9v
From reading this thread I know there is something up as my measurements do not match everyone elses. I tried the old Rectifier/Regulator and there were no changes in these voltages.
iooi
PostPosted: 22:54 - 01 Mar 2016    Post subject: Reply with quote
So either the Rectifier/Regulator is fucked or you have wired it up wrong when changing the charging system.
oliverpetrie
PostPosted: 23:00 - 01 Mar 2016    Post subject: Reply with quote
Nope Its a Yuasa one :/
The last post was made 10 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 129.98 Kb
