HIDs
Draco87
PostPosted: 22:27 - 29 Feb 2016    Post subject: HIDs Reply with quote
Hi guys I've just purchased and installed a pair of HIDs on my 2000 R6. It was a simple procedure to do a plug an play from the stick bulbs. The kit I have is a 35w 6000k bi-xeon light. Sadly I'm at a loss to the issue. When I turn the lights on only one side will come on, turn them off and on again the other side will light only, they both try and fire up but only the one will light. I took it out for a ride and turned the high beam on and off again and both lights stayed lit, after a short time only the one would stay on usually the right one. Also if I use the pass button both will try to fire but again one side stays lit, sometimes it will alternate between which stays on. I have also had it when I turn the lights on that neither will even light up. Am I missing something. I've checked the connections they seem ok. Could it be a power source issue, I've ordered a new reg/rec has I think that may need changing from a previous issue. Any advice will help as this is the first time of me using these
1992 Yamaha SR125, 2005 Honda XR125, 1998 Yamaha XJ600S, 2000, 2004 Yamaha R6, 2002 Yamaha Fazer, 2004 Honda CBR
TheManWithThe...
PostPosted: 19:51 - 01 Mar 2016    Post subject: Reply with quote
Have you tried swapping the leads over between the bulbs and the ballasts?
That way you at least know which one is the problem.
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
Draco87
PostPosted: 20:41 - 01 Mar 2016    Post subject: Reply with quote
No I haven't tried that, I never thought about that in fairness but I will give it a try tomorrow and let you know what happens
The last post was made 10 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 14 - Page Size: 36.15 Kb
