| talkToTheHat |
 talkToTheHat World Chat Champion
| Vincent 2 |
 Vincent 2 Nova Slayer
| Pete. |
 Pete. Super Spammer
 Posted: 06:22 - 01 Mar 2016 Post subject: |
Mine went on reserve on 2 bars. Full to the very brim I used to get between 125 and 140 miles to reserve with another 50 miles in the tank. If I rode particularly frugally I could just about stretch it to 200 miles if it had a newish air filter (which added about 15 miles range over a filthy dirty one).
If this is similar to what you are getting that would suggest it to be quite normal. ____________________ a.k.a 'Geri'
| Kris |
 Kris World Chat Champion
 Posted: 08:02 - 01 Mar 2016 Post subject: |
Are you switching to reserve when the fuel light (flashing fuel bar) comes on - or when the bike begins to bog down and demand it? I think there's a big difference and I seem to remember ignoring the fuel gauge and relying on the trip instead. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Evil Hans |
 Evil Hans World Chat Champion
| talkToTheHat |
| mudcow007 |
 mudcow007 World Chat Champion
| talkToTheHat |
| Pete. |
 Pete. Super Spammer
 Posted: 05:08 - 03 Mar 2016 Post subject: |
Should be about 13-14 litres.
If It's bothering you - run it dry, remove the tap and cut the delivery pipe down about a bit. ____________________ a.k.a 'Geri'
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| mudcow007 |
| mudcow007 |
| Dabura |
 Dabura Nova Slayer
| talkToTheHat |
| Kaya75 |
 Kaya75 Trackday Trickster
| talkToTheHat |
| Pete. |
 Pete. Super Spammer
| Polarbear |
 Polarbear Super Spammer
| talkToTheHat |
 Posted: 16:49 - 08 Mar 2016 Post subject: |
Centrestand didnt seem to make much of a difference behind giving me further ways slip over in a petrol station.
Got home earlier 160 miles after brimming it, been on reserve for the last 20 miles, drained out more than 5 litres of fuel. If the petrol is indeed .734 kg/l as a quick google suggests, then 6.0 litres to 2sf.
Watched fuel gauge as it was draining and it does indeed have full range of readings and is working ok.
Had the petcock off, there was a little buildup of brown semi-congealed goop around the lower portion of the main fuel take off. Cleaned it and reinstalled. Is a push fit so i can always modify if it's still a problem. 15mm of correlates with how early my reserve has been. Now i know i have 6 litres in the tank i shall get to the petrol station approx 1/2 mile away and see how much makes for full. It might even run on main not reserve to get me there.
Just to annoy me, i appear to have got better than average fuel economy on the last tank, not surprising really as i went ofer the tops to avoid traffic and barely put my feet down. It will all make sense when i fill up.
On taking the tank off i realised one of the breather hoses that connects underneath has a t-piece and an extra lengh of hose. I am confused. There does not appear to be anywhere it should be connected to. See photo. Is it a relic from an emissions control device? Have i got the vacuum take off for someone's scott oiler instead of a breather hose?
https://cdn.bcf.44bytes.net/files/img_20160308_141539039.jpg ____________________ Bandit. does. everything. |
| Pete. |
 Pete. Super Spammer
 Posted: 18:58 - 08 Mar 2016 Post subject: |
If that's a breather the T will be an anti-syphon. It's to stop all the fuel from syphoning on to the road if the bike goes over. A syphon will (probably) always stop if it is allowed to draw in air. ____________________ a.k.a 'Geri'
| talkToTheHat |
The last post was made 9 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
