Tool talk: Individual sockets, torque wrench, spanners?
NJD
PostPosted: 19:23 - 14 Mar 2016    Post subject: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
I'm on the hunt for a mix of tools to add to my toolbox as and when either I can afford them or need to use them but before I put my money down on anything I'd rather get some opinions than having to buy twice. Personally I'm not after the best of the best or most expensive and rather something to go to should and when I need it for any given job.
Individual sockets
Looking at individual sockets because they're cheap and I'm only looking to fill in the gaps of the sockets that I don't currently own or will need rather than to buy a set that I'll only end up using a few out of. Amazon seems like the best place to buy from for these.
Silverline, drapper or bacho?
There's a niggle inside of me that tells me it's drapper v bacho. Other brand suggestions welcome. I only list those three because they seem the most popular and have a range of 6pt sockets in the strength and size I'd need.
Torque wrench
A minefield. You get what you pay for in terms of quality. A tool that does an important job and therefore the ones that do that job well have a price point to meet it.
I call the haynes manual a useless piece of shi* in this area because it lists generic torque settings and doesn't even include a torque setting for the rear wheel axle nut on the "installation" section for the rear wheel so I'm non the wiser. Anyway the haynes says:
5mm bolt/nut - 5nm
6mm bolt/nut - 10nm
8mm bolt/nut - 24nm
10nm bolt/nut - 35nm
12mm bolt/nut - 55nm
So a range of 5nm-55nm for most jobs and then it lists a few random torque settings per chapter for example "Chapter 2: Rocker assembly bolts - 12nm". Again convenient it leaves out a setting for the rear wheel axle nut. I'm sure I'll discover a lack of torque settings if and when those jobs arise but I just picked an obvious job and found a rather silly flaw.
Spanners
I've got my eye on this Silverline SP100 6-32 Spanner Set that (I think) was recommended by Paddy on another thread. I haven't purchased it yet because funds and not needing them yet. Anyway, that's the spanner set sorted.
As for individual combo spanners I assume that any old combo spanner sold by Amazon, BNQ, Homebase (or anywhere else) would be good enough to fill in the gaps in that set or just to have more than one of the same size? Spanners are generally cheap enough to just buy a cheap backup one once you've got a decent set, right?
Also is there any need for any other type of spanner other than a combo spanner, ie; open end?
Many questions, sorry. Thumbs Up Karma
PostPosted: 19:49 - 14 Mar 2016    Post subject: Reply with quote
Just do wheel axles up really tight. Wink
You can never have enough spanners, regardless of how many sets you have, you won't be able to find an 8mm/10mm/12mm when you need one. Razz
Ratchet spanners can be useful for some jobs. Like header pipes.
Acquire a copy of the manufacturers workshop manual rather than using a Haynes manual. Thumbs Up
NJD
PostPosted: 20:04 - 14 Mar 2016    Post subject: Reply with quote
Chinese 125 so a haynes manual that covers all similar models with generic advice rather than model specific is as good as it gets outside of this forum or info found on google.
Sums up my experience earlier today whereby I needed a 13mm spanner to tighten an indicator locknut and either I genuinely don't have one or couldn't find it and so had to improvise with a pair of pliers. Bodge job galore. Laughing
B5234FT
PostPosted: 21:59 - 14 Mar 2016    Post subject: Reply with quote
Halfords advanced for me, lifetime warranty and you can replace them on a Sunday afternoon. Good range and all inexpensive. If you can blag/find someone with a trade card then it's even cheaper.
Only exception is I have a 1/4 deve torque wrench which is remarkably handy from TENG.
Pete.
PostPosted: 22:04 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
Individual sockets
Torque wrench
5mm bolt/nut - 5nm
6mm bolt/nut - 10nm
8mm bolt/nut - 24nm
Spanners
Boot fair. Take £20 and come away with a big bag of spanners plus change.
a.k.a 'Geri'
DRZ4Hunned
PostPosted: 22:12 - 14 Mar 2016    Post subject: Reply with quote
I wouldn't worry about torquing stuff unless you're working on the engine. If you can be bothered sifting through all the shit at auto jumbles you might be able to find some bargains.
DRZ400-SM
FZS600
sickpup
Old Timer
PostPosted: 22:16 - 14 Mar 2016    Post subject: Reply with quote
The biggest question here is whats your budget?
What I spend on tools, no where near what others spend on Snap-on is unlikely to be what you want to spend, I've spent a couple of hundred in the last month on ratchets alone and £430 on a new bottom cabinet today.
NJD
PostPosted: 22:52 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
Google search doesn't return any local auto jumble specific events (well it does but that one's passed and no date for another one) however I'd forgot totally about the carboot that runs in the city center every Sunday morning. Worth an early morning when I next get the chance to see if there's any tools or other bargains I like the look off.
The only thing that the budget would determine would be the Torque wrench because I'm only after a suggestion for a brand that sells sockets individually of all strengths and sizes to the public and is off a reasonable price and quality. Spanners are also somewhat sorted in that if the carboot doesn't turn up anything the silverline set on amazon are cheap enough and have come recommended.
So, Torque Wrench. A range of 5nm-55nm is recommended in haynes just for all round general use. I have no idea what nm is realistically required since i'm a mechanical novice. You suggest what the highest nm would realistically be just to get started and then suggestions can be made by yourself. Do keep in mind we're talking a basic budget end 125 with a 157fmi engine. Budget also depends on how much use I'd actually get out of one. I only want a torque wrench so that I can say I've got one should I need to reach into my toolbox and use it if and when required.
So all I really require is a torque wrench so that I've got one rather than not having one that will cover all the basic jobs and torque nuts and bolts up that need it since I don't really have a "feel for it" yet. Would probably sit in the toolbox more than it would be used.
I'd assume anything basic that's accurate and low budget would do for now? £20-40 realistic?
wodge
PostPosted: 23:00 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
This!!!!! Thumbs Up
I bought a 20 quid box of sockets a couple of years ago at a boot fair. Most sockets were 1/2 drive snap on, britool, king dick etc ranging from 8mm to 30mm. Also included were a couple of ratchets and snap-on extension bars. The bastard seller wouldn't haggle on them either, i had to pay asking price.. Sad
Saying that i am a fan of bahco and Halfords professional sets, they are always on offer and not bad quality
nolidge iz pouwur.
Yamaha RXS100 RS100
sickpup
Old Timer
PostPosted: 23:26 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
So you would be happy to pay £25 for a 27mm deep reach socket?
mauzo
PostPosted: 23:46 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
Your Chinese 125 will be basically the same as my CG. There are a couple of nuts with torques higher than that: rear axle nut, swingarm pivot nut 88 Nm; steering stem nut 74 Nm; front axle 62 Nm. I can't see anything else over 55 except the generator rotor bolt, and I doubt you'll be getting that far into the engine. [Slightly weird numbers because I've converted them from kgf·m.]
Even if you don't get a wrench that goes up past 90, see if you can borrow one at least once to do your axle bolt up, just to get a feel for it. 90 Nm is probably more force than you think it is.
'04 CG125, '07 CBF500
Raffles
PostPosted: 23:53 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
Recommended by who?
NJD
PostPosted: 23:55 - 14 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
wodge wrote:
bought a 20 quid box of sockets a couple of years ago at a boot fair. Most sockets were 1/2 drive snap on, britool, king dick etc ranging from 8mm to 30mm. Also included were a couple of ratchets and snap-on extension bars. The bastard seller wouldn't haggle on them either, i had to pay asking price..Sad
Sounds like a fair price for such a haul. I'd hazard a guess that the sad face is because £20 would be expensive by car boot standards?
Also are king dick tools good? I only ask because I'm sure I discovered a couple of king dick spanners in some tools I got given for nothing recently.
Probably not, at this point in time that is. As it stands I'm currently looking for tools that are of good enough quality to withstand and deal with light use and DIY maintenance and servicing for a novice. I'd say I'm after as much as I can get for as little money as possible for now to get what I need or think I need to build a basic set up and then to upgrade as and when needed over time.
Draper / Bacho individual sockets seem fairly priced on Amazon. £6.95 for a Draper 1/2 25mm 6pt standard socket for example. However, in the same that by asking questions I learnt Kriega is the go to luggage should I find myself needing a better version of everything for some serious use in the future despite only currently owning cheapo brands that get my by I'd happily take suggestions for brands that I'd do well to keep my eyes out for either at car boots as people getting rid off their old collections or as something to upgrade to in the future once I've got all my basics out the way.
mauzo wrote:
*figures*
More information than the haynes provides. Many thanks. Thumbs Up
monkeybiker
PostPosted: 23:55 - 14 Mar 2016    Post subject: Reply with quote
I only use a Torque Wrench for very tight nuts, for low torque I go by feel and have had no problems.
Clutch bolt or front sprocket bolt I feel a torque wrench is useful as it's quite a bit of force needed to tighten them and I wouldn't want them coming off.
NJD
PostPosted: 00:03 - 15 Mar 2016    Post subject: Re: Tool talk: Individual sockets, torque wrench, spanners? Reply with quote
Raffles wrote:
Recommended by who?
G. Sorry paddy, I guessed wrong before.
This set.
finniee
PostPosted: 00:36 - 15 Mar 2016    Post subject: Reply with quote
Personally I have :
Halfords 30 piece socket set 1/4"
Halfords 1/2" Drive ratchet
3 piece mole grips 8 different pliers
Hilka 1/2-inch deep sockets
1/2" breaker bar
about 20 different kind of screw drivers, ratchet style screwdriver ( cheap pos does the job), different sizes of bits.
Honda CBF125
bamt
PostPosted: 01:28 - 15 Mar 2016    Post subject: Reply with quote
I use one of these Halfords 8-60Nm torque wrenches. It's perfect for almost everything on a bike except axle nuts - and they just go FT.
I've also got a beam wrench that I use a lot; the ratchet click-wrench is great for doing multiple fasteners up to the same torque (like gradually tightening up a cylinder head, where you have a dozen nuts to do up several times as you work towards the final tightness), whereas the beam is faster for doing one-off bolts as you don't have to set it up then unwind it afterwards.
talkToTheHat
PostPosted: 04:53 - 15 Mar 2016    Post subject: Reply with quote
Spanners fit where a socket doesn't. Sockets fit where spanners dont. Hexagonal wall-drive sockets don't chew bolt heads. Cheap 12-point spanners do. I have a 17mm single hex britool spanner specifically for the sump plug on a virago which has a footpeg in the way of where a socket needs to be. Dont lean on anything with a cheap 12-point ring spanner unless you want it broken.
I have some cheap cast spanners that claim to be draper. They are made of special cheese that mostly bends but occasionally devours unsuspecting bolts. I have some cotech ones that may not contain as much chrome as advertised and are rust magnets. The few britool ones i have are nice, they dont chew bolts and they ring a much nicer note than anything else, which i thing means their internal structure has less voids. Seriously, good spanners ring and shit ones go clack.
Spanners and sockets in 8, 10, 12, 13, 14, 17 plus anything big for axle bolts. I have 21, 22, 24 in 1/2" and a 2ft breaker bar. Short halfords 1/4" ratchet handle, short halfords 3/8" with a handle that flips back for rapid spinning, and a sensible size 3/8" ratchet. The ratchets will be in your hands a lot. Avoid plastic handles for automotive work, they will get eaten by fluids. I like feel of the halfords ones.
Top quality screwdrivers, know what is pozi and what is philips. Modern phillips and JIS are compatible, less so with 80s bikes. A single phillips does most of my motorcycle duties, it's due an upgrade.
Bandit. does. everything.
bamt
PostPosted: 07:35 - 15 Mar 2016    Post subject: Reply with quote
The standard Draper range can be ropey (things like spanners having uneven edges and ridges from where the casting mould halves join - as you'd expect on eBay Chinese specials not an established western brand). The Expert ones tend to be OK.
talkToTheHat
PostPosted: 13:26 - 15 Mar 2016    Post subject: Reply with quote
Yes, my drapers are not 'expert'. I think there is an important distinction.
sickpup
Old Timer
PostPosted: 15:02 - 15 Mar 2016    Post subject: Reply with quote
At the prices you are willing to pay I agree either car boot or Bahco but you are probably better off buying in sets.
There is also nothing wrong with Bi-hex sockets as long as you buy quality ones, they also work on the f;ats not on the corners.
ScaredyCat
PostPosted: 15:14 - 15 Mar 2016    Post subject: Reply with quote
Are Bahco considered: just about ok, good enough, reasonable or good quality?
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
mudcow007
PostPosted: 15:15 - 15 Mar 2016    Post subject: Reply with quote
Every silverline tool* I've ever had the misfortune to use has broke/ rounded off or slipped an took chunks out of my knuckles and left me in a worse situation than when i started
*I use the term "tool" loosely
Another vote for Halfords advanced or what ever they call them these days - they aint the cheapest but im yet to break any - the boxes they come in are made of cheese though
pepperami
PostPosted: 15:18 - 15 Mar 2016    Post subject: Reply with quote
cheap cast spanners, they are made of special cheese that mostly bends but occasionally devours unsuspecting bolts.
Good spanners ring and shit ones go clack..
All of the above^
I have actually chucked out a handful of those nasty 12 sided cheap ring spanners to stop me using them and rounding off nuts (clumsy/heavy hands).
The last post was made 10 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 142.6 Kb
