| Daugaard |
 Daugaard L Plate Warrior
 Posted: 19:29 - 18 Mar 2016 Post subject: Aprilia RS 125 won't start - unusual problem. |
Hello BCF
Last year my motorcycle went dead on the road. I have not taken care of it since.
What happened was, the bike lost a lot of power! When I shifted to the 5th gear, the bike didn't have any torque to put out power - it dropped in RPM and I had to downshift into 4th gear. When i got to the nearest unconditional right of way, the bike went out, and I have not been able to power it up since. When I try to start it, the motorcycle sounds very different than it used too.
What I know:
-The piston is going up and down just fine (also when the electrical starter is engaged).
-The sparkplug delivers a good connection and spark.
-It gets gas and air just fine.
-I tried to put it in the 1st. gear, and the motorcycle is running forward when hitting the electrical starter.
What could this problem be?
-Daugaard  |
| Ariel Badger |
 Ariel Badger Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 13:44 - 19 Mar 2016 Post subject: |
Compression check. Firstly as above, but better to buy a compression tester and try it properly (take plug out, screw in tester, crank over with the throttle wide open until the reading stops going up - take care the hold the spark plug against an earth while cranking to give the ignition system an easier time).
Should be well over 100psi in good condition, a bit under 100psi and it will still run but be marginal. Suspect yours is a long way under 100psi
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 17:54 - 19 Mar 2016 Post subject: |
^^This^^
You need 4 basic things to make the engine run:
1. Correct fuel/air mixture.
2. Good compression.
3. A spark to ignite the compressed fuel/air mixture.
4. The spark needs to happen at the right time.
You say 1 and 3 are fine, that just leaves 2 and 4 to be checked. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| stevo as b4 |
The last post was made 10 years, 216 days ago. Instead of replying here, would creating a new thread be more useful? |
