| Kaya75 |
 Kaya75 Trackday Trickster
 Posted: 21:57 - 18 Mar 2016 Post subject: Braided brake line supplier |
Alrite all,
I'm going to overall my brakes on the bandit at Easter, I'm looking at lines and wondered if there's any recommendations on makers and suppliers.
Anywhere online I can order from?
Cheers all  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| RhynoCZ |
 RhynoCZ Super Spammer
| Commuter_Tim |
 Commuter_Tim World Chat Champion
 Posted: 22:24 - 18 Mar 2016 Post subject: |
I don't own a Bandit or have knowledge of its brakes, but www.wemoto.com are a reliable parts supplier and are a pleasure to deal with.
Everything listed isn't always everything they have so worth contacting them if there is a specific part you're after.
They do however sell mostly (but not exclusively) pattern parts though. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| talkToTheHat |
 talkToTheHat World Chat Champion
| Busa1340R |
 Busa1340R Nova Slayer
| Kaya75 |
 Posted: 11:59 - 19 Mar 2016 Post subject: |
Thanks All
Wemoto have a 3 to 4 day lead time which isn't that terrible,
I'm looking at Sportbikeshop have everything I need (filters, pads lines etc.)
I'd kind of settled for HEL - but will look at venhill too - I'm going to stay OEM setup too.
I'm going to split the rear calliper for a good clean and replace the piston seals and any O rings - I need to find a breakdown diagram.
Mate at work as tipped me to hold the callipers up above the MC for bleeding - I never thought of this - The last twenty years worth of oil and grease on my hands (Washed off with blood sweat and tears..) has come from rebuilding air-cooled VW's so all bike tips are welcome.
Thanks All
| Kickstart |
 Kickstart The Oracle
| Kaya75 |
 Posted: 18:58 - 20 Mar 2016 Post subject: |
Thanks for the heads up
I'll try to get the o ring just in case, I'll polish up the pistons and replace the piston seals anyway
I'm hoping the pistons are free - the rear brakes are still fine to be fair but the fronts are not so fine - gotto love winter riding
I'll have the calliper off anyway so the pins will be easier to get to and to put a bit of heat on the alloy if they are seized.. just off to order up the bits now along with a new fat tube of copper slip - thanks all  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| Kickstart |
 Posted: 19:42 - 20 Mar 2016 Post subject: |
Fronts are a doddle. Yes the seize (both the pistons and the pins the calipers slide on), but being sliding calipers it is very easy to pump the pistons out. Getting the caliper off the sliding pins can be a pain, but normally doable.
With the rears the ping the pads mount on is a nightmare. Heat, abuse, lube, etc, very occasionally work . Best way seem to be to slather the pin in decent penetrating oil and then clamp it with some mole grips (decent pair can grip tightly enough - no chance with pliers). Then try and twist with the mole grips. Problem is doing this with the pads in place.
One the pads are out you can pump the pistons out as long as you haven't taken the caliper off completely (ie, still hydraulically connected). Note that where the banjo bolt connects gives you a way to push one piston out (ie, push through the banjo bolt hole), so try and get the other piston to pump out first (ie, get them both most of the way out, but with the one on the banjo bolt side not quite as far out when the other pops out)
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| smallfrowne |
 smallfrowne Scooby Slapper
 Posted: 10:04 - 21 Mar 2016 Post subject: |
You've got enough brake line recommendations, however I thought I'd chirp in just 'cause I've had good dealings with the bloke.. https://www.wezmoto.co.uk/ ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| haroman666 |
 haroman666 World Chat Champion
 Posted: 10:55 - 21 Mar 2016 Post subject: |
I have put HEL lines on both my bikes.
Can't fault them.
Well made product. Good options for colours etc. Easy to fit. Price is perhaps higher than other available products but I think being a reputable product reflects that.
https://www.helperformance.com/
Disclaimer: I don't work for HEL or have any association with HEL or the sale of products related to HEL. Just an advocate of their products. ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| bladeblaster |
 bladeblaster Trackday Trickster
| bigup |
 bigup Nitrous Nuisance
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
The last post was made 10 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
