Problem with Dragstar 650
Balarama108
PostPosted: 14:03 - 07 Apr 2016    Post subject: Problem with Dragstar 650 Reply with quote
Hi there, 3 month ago I bought a 2002 Dragstar 650 Custom with only 12.5k miles on the clock. Sofar she has been running great but yesterday something strange happend.
I was on the motorway and she was running fine but when I got her up to 60mph I noticed a strange "thumping". It's hard to describe... It felt like something isn't running smooth, somewhat like a tumble dryer with an uneven load. I didn't hear anything with the wind noise but could feel that "thumping/rattling" through the footpegs.
When I let off the gas it stopped. Putting it back on and the "thumping" seemd less. The same thing happend today only I had to let off the gas two or three times.
Does somebody have an idea what could cause this?
Both engine and crank oil levels are fine and it only happens when I hit 60mph
jaffa90
PostPosted: 14:39 - 07 Apr 2016    Post subject: Reply with quote
Sounds like it`s running on one cyl at this speed, could be tight valve clearances on one cyl or a carb running dry.
Balarama108
PostPosted: 22:12 - 07 Apr 2016    Post subject: Reply with quote
Thanks man!
I guess I'll have to bring her back to the shop not being overly mechanically gifted myself but it helps if I can give them some idea where to look instead of just a vague "thumping" something....
doggone
PostPosted: 22:34 - 07 Apr 2016    Post subject: Reply with quote
There will probably be some kind of balancer mechanism driven by chain (I guess) - could need attention.
Make sure engine mounting bolts all present and correct.
Robby
Dirty Old Man
PostPosted: 08:15 - 08 Apr 2016    Post subject: Reply with quote
Service it before you go looking for a problem.
There are many things that can cause a thumping noise - from one cylinder not working due to lack or fuel/air/spark, through valves being massively out of adjustment and on to more terminal things. It could also be a frame/wheels problem rather than an engine problem.
The cheapest possible problem is duff spark plug or HT lead, or even just a loose spark plug. On many V-twins the front spark plug and HT lead get a hard time because they get wetter, both from being at the front of the engine and from crap thrown up that way from the wheel. SV650s were notorious for it.
Give it a proper service - oil, filters, plugs. Drain the carbs into a cup and look for water in the fuel while you're at it. Don't get into any diagnosis work until the service is done, you'll just be pissing money up the wall.
talkToTheHat
PostPosted: 23:36 - 09 Apr 2016    Post subject: Reply with quote
See above. Do service before clutching at straws.
Bandit. does. everything.
The last post was made 9 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.03 - MySQL Queries: 14 - Page Size: 46.85 Kb
