Kawasaki GPZ500s New Oil Filter Leak
KurtJ
PostPosted: 20:00 - 04 Apr 2016    Post subject: Kawasaki GPZ500s New Oil Filter Leak Reply with quote
Hey,
Yesterday I changed my oil and fitted a new filter for the first time - under the guidance of someone who is pretty good with general mechanics etc.
All seemed fine, had run the engine for a good while with no leaks.
However, today when I have started it up I'm getting an oil leak which appears to come from the new filter. But then it stops. And then when I started it up again, another leak of oil comes out then it stopped again...
Any ideas? Thanks!
MCN
PostPosted: 20:03 - 04 Apr 2016    Post subject: Reply with quote
Kawasaki really want their oil filters rammed on as tight as fuck.
Hand tight is waaaaaay too slack.
Check what it says in the book.
zzpza
PostPosted: 21:13 - 07 Apr 2016    Post subject: Reply with quote
Hand tight and then 1/4 turn has worked well on my '94 GPZ 500S so far. Did you make sure to oil the rubber seal before installation, and clean the mating surface?
It's pretty exposed on the front of the engine (if you have no fairing) so is easy to get road debris fouling the filter seal when you install it if you don't clean the area before removing the old filter.
pompousporcup...
PostPosted: 21:19 - 07 Apr 2016    Post subject: Reply with quote
as above, although even the lower fairing has a hole in the middle that allows crud to get kicked up from the wheel and cake the filter.
tighten it as hard as you dare, clean up the surrounding area and see if it comes back.
KurtJ
PostPosted: 15:10 - 08 Apr 2016    Post subject: Reply with quote
Hey everyone, after seeing first post I got myself a strap-wrench to tighten it up a bit, as it was only hand tight - and that has sorted it out, no more leaking oil.
Thanks for the advice people, much appreciated!
The last post was made 10 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 14 - Page Size: 42.37 Kb
