| Pete. |
 Pete. Super Spammer
 Posted: 15:21 - 10 Apr 2016 Post subject: Broken stud extractor - how to remove. |
I helped a guy today who had a broken-off stud extractor stuck in an exhaust stud. These are too hard to drill so I used an old machinist's trick for removing busted centre drill ends.
I took a 11mm diameter centre drill with a broken end and ground it as shown below. I also made a drilling guide to keep it aligned central over the broken stud. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 15:25 - 10 Apr 2016 Post subject: |
Used the tool to drill over the top of the stud extractor which was sheared off below surface. I cut as much of the ally out from around the stud as I could, even hit the stud with my welder to melt the top down a bit to gain a bit of extra depth.
Once it was cored out as far as I could I built the top of the stud up with weld. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 15:28 - 10 Apr 2016 Post subject: |
Once the weld was high enough I welded a nut to it and with all the heat involved it screwed out easily with a spanner.
The drilling guide did a great job and there was plenty of thread left so I just made an extended stud to go into the original thread.
Done start to finish in about 2.5hrs. ____________________ a.k.a 'Geri'
| ondabike |
 ondabike Borekit Bruiser
 Posted: 15:31 - 10 Apr 2016 Post subject: |
Excellent demo Pete, will try that if I have to  |
| zzpza |
 zzpza Derestricted Danger
 Posted: 15:50 - 10 Apr 2016 Post subject: |
Impressive work, not sure I have the skill to manage that!
I've been waiting for an opportunity (hopefully on none of my bikes) to try this method:
https://www.youtube.com/watch?v=fqZYgReuywM |
| Islander |
 Islander World Chat Champion
 Posted: 16:18 - 10 Apr 2016 Post subject: |
It's an old watch/clockmakers trick and it does work. It's a lot slower than Pete's method though  |
| Pete. |
 Pete. Super Spammer
 Posted: 17:00 - 10 Apr 2016 Post subject: |
| Islander wrote: |
Also couldn't be done in place. The guy had already removed the cylinder head but I could have done it in place though it would have been a lot more awkward.
The best bit about this was I didn't have to use a lathe or mill, just an angle grinder, battery drill and welder so it's possible for anyone with those tools, all you have to do is get hold of a centre drill which are pretty cheap. ____________________ a.k.a 'Geri'
The last post was made 10 years, 1 day ago. Instead of replying here, would creating a new thread be more useful? |
