| nightrider011... |
 nightrider011... L Plate Warrior
| P.addy |
 P.addy Formerly known as P.
| nightrider011... |
| MarJay |
 MarJay But it's British!
 Posted: 13:21 - 21 Apr 2016 Post subject: |
Why do people mess around with perfectly working bikes?  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| nightrider011... |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:45 - 21 Apr 2016 Post subject: |
| nightrider0113 wrote: | i did but i have the same problem, there was a screw on the bottom of the carb on the cylinder side that i thought was my idle screw but then when i found out it wasnt i couldnt remember how many turns id turned it, what does it do what could that be it? |
Sounds like your mixture screw. Depending on how the carb is set up, clockwise is either going to make the mixture leaner or richer, so the direction in or out will be dependant on how it acts. You might be lucky and be able to google what the default number of turns out is as a starting point. Otherwise...
Screw it all the way in GENTLY and then unscrew 1 turn. Set your IDLE screw for a fast idle, then SLOWLY turn the mixture screw out, 1/8th of a turn at a time, until the revs stop increasing and start dropping again. Do this progressively - adjust then let it settle, adjust, settle. Reduce your idle, and then keep turning the mixture, raising the revs again. When the revs no longer increase, turn it back 1/8th of a turn and make a note of how many turns out this is.
Should get you to ballpark area of where it should be.
[edit] Made the starting point 1 turn, as 1.25-1.5 might be where it should be. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:17 - 21 Apr 2016 Post subject: |
Going back to stock is always a good idea. Whatever you do, don't just start throwing more "performance" bits at it in the hope that it'll get faster. In particular, a cone air filter is as likely to harm as to help.
| The Shaggy D.A. wrote: | to google what the default number of turns out is as a starting point. |
If it's this carb...
https://i.imgur.com/VbDZL7C.png
I'd start 2 turns out.
5th gear won't necessarily give you any more speed than 4th on these bikes, and your gearing change may have moved the power curve where it can't make it to peak power. That said, it won't effect starting or running up the gears, so it sounds like you've knackered the fuelling.
For reference, my copybike 125 had a 90 main jet as stock and ran slightly lean (thanks, Brussels). 95 was about right, 100 was OK after de-catting the exhausts, but 105 was too much.
Did you move the needle? Or is there any chance you've dislodged it, or meddled with the float?
Have you actually been out with your 70mph chum to verify his claim? ____________________ Biking is 1/20th as dangerous as horse riding.
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 15:20 - 21 Apr 2016 Post subject: Re: rejet gone wrong, help? |
| nightrider0113 wrote: | my bike makes a bang when its first started on a morning and feels more sluggish than before, what have i done wrong? |
Firstly take note of what messers Shaggy and Borg have said.
Secondly, (pedant mode), the "mixture" screw they're referring to is actually the pilot jet, on that carb!
The pilot jet affects 0 to 1/4 throttle openings, so even when you get this back in the right place, (somwhere between 1.5 & 2.5 turns out), it's not going to affect the top end at throttle openings of more than a 1/4!
Go back to the standard jetting and start from there, adjusting the pilot jet as Mr Shaggy suggested.
Marjay, consider yourslf told, op obviously just wanted a tummy rub!  ____________________ "Everybody needs money, that's why they call it money!"  |
| Rogerborg |
 Rogerborg nimbA
| stevo as b4 |
| temeluchus |
| nightrider011... |
The last post was made 9 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
