| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 10:25 - 20 Apr 2016 Post subject: Fuel pipe Diameter? |
If you haven't seen it in "Show and Tell", my project bike, (Honda XL125RC), was finished, up and running and on the road last year, it runs ok but it has always been difficult to start, (no electric foot).
Yesterday I changed the fuel pipes from 5mm to 6mm ID.
I have just been out to start the bike up and, for the first time ever, it started up on the first kick.
After cutting the choke then letting it warm up for a few minutes, the idle speed seems to have increased by 2 - 300rpm.
According to my calculations, increasing the fuel pipe diameter by 1mm equates to a 44% increase in pipe volume!
There is no fuel pump or vacuum fuel sytem, it's just a gravity feed, I fitted an inline fuel filter, when I built the bike.
So, is it really possible that increasing the fuel pipe diameter has changed the flow of fuel enough to cure a difficult to start bike, or is this all just coincidence? ____________________ "Everybody needs money, that's why they call it money!"  |
| MarkJ |
 MarkJ World Chat Champion
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 10:40 - 20 Apr 2016 Post subject: |
Hi had you already changed the jets or is this just with the bigger dia pipes , am new to this forum so had`nt seen your build  |
| Suntan Sid |
 Posted: 10:52 - 20 Apr 2016 Post subject: |
| MarkJ wrote: | Could it be the warmer weather we've been having? (If you're still in blighty) My carb'd bikes always seemed a lot easier to start once the weather started getting warmer. Not sure on the increase in RPM though |
It was near to freezing here, (Buxton), last night.
It's always been the same even in the summer?
| Meatybeaty wrote: | Hi had you already changed the jets or is this just with the bigger dia pipes , am new to this forum so had`nt seen your build  |
This is just with a larger diameter fuel pipe.
I had, initially, made a mistake with the clip position on the needle, I did sort this out, some time ago, but it made no difference to the difficult starting, just changed the colour of the plug, slightly, it had been running slightly rich! ____________________ "Everybody needs money, that's why they call it money!"  |
| Meatybeaty |
 Posted: 10:56 - 20 Apr 2016 Post subject: |
Cheers Suntan , will remember that one for future reference , could be of help to a lot of poor running bikes on here  |
| BTTD |
 BTTD World Chat Champion
| spottedtango |
 spottedtango Trackday Trickster
| Suntan Sid |
| Fizzer Thou |
 Posted: 17:38 - 20 Apr 2016 Post subject: |
There was a post on BCF a while ago where someone had a fuel flow problem and it was narrowed down to the in-line filter.From what I remember,until the filter became saturated,it effectively caused a vacuum and only a trickle of fuel flowed to the float bowl.
Maybe,now that the new in-line filter has been on the bike for some time,the flow has increased  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Pete. |
 Pete. Super Spammer
 Posted: 18:12 - 20 Apr 2016 Post subject: Re: Fuel pipe Diameter? |
| Suntan Sid wrote: | If you haven't seen it in "Show and Tell", my project bike, (Honda XL125RC), was finished, up and running and on the road last year, it runs ok but it has always been difficult to start, (no electric foot).
So, is it really possible that increasing the fuel pipe diameter has changed the flow of fuel enough to cure a difficult to start bike, or is this all just coincidence? |
Once the carburettor bowl is full and the float valve shuts off no significant amount of fuel will flow through the pipe until the bike is running. The size of the fuel line will therefore have no bearing on the way it starts. ____________________ a.k.a 'Geri'
| Ariel Badger |
 Ariel Badger Super Spammer
| Suntan Sid |
 Posted: 19:30 - 20 Apr 2016 Post subject: |
I'm happy with "coincidence"!  ____________________ "Everybody needs money, that's why they call it money!"  |
| Suntan Sid |
 Posted: 11:21 - 21 Apr 2016 Post subject: |
Right, just been out to start it up, started first kick again, hoorah!
I'm happy to accept this is all just coincidence, but I've never been able to start this bike easily, it would alway require multiple attempts, even when I was using it daily last autumn, to run it in.
In the past I would kick and kick it, it would, reluctantly, catch then die straight away, doing this, at least, half a dozen times, at five minute intervals, it would eventually tickover on choke, but giving it any throttle would kill it. I would then have to leave it ticking over for at least 5 minutes before I could touch the throttle!
Now, first kick, it fires and idles on the choke, I can knock the choke off after 10 seconds and it responds to the throttle without coughing and conking out!
It just seems very strange, all I've done is change the fuel lines, even if there'd been dirt in the carb, I don't see how I could have dislodged it.
Coincidence or not, I'm still happy!  ____________________ "Everybody needs money, that's why they call it money!"  |
| The Artist |
 The Artist Super Spammer
 Posted: 12:01 - 21 Apr 2016 Post subject: |
Yeah, it definitely sounds like something has cleared itself up in the carb area. Always nice when that happens without you having to do anything.  |
The last post was made 9 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
