Honda Hornet Clocks Issue
leecurtis89
PostPosted: 12:13 - 26 Apr 2016    Post subject: Honda Hornet Clocks Issue Reply with quote
Hey, this is my first post and i'm trying to find the root cause of an issue im experiencing with my new bike.
Bike: Honda Hornet CB600F-8
Issue: Rev needle stuck at 4k, no mileage info displayed, no engine management displayed. Lights working, starts first time every time, neutral light working.
Video: https://youtu.be/i6dFsghsTxI
Any help or suggestions would be much appreciated, i look forward to being involved on the forum!
Lee
PostPosted: 12:40 - 26 Apr 2016    Post subject: Reply with quote
Some bikes you the rev counter as a readout for an error code. that would indicate to me you have error 4.
PostPosted: 12:43 - 26 Apr 2016    Post subject: Reply with quote
Actually ignore that I've just watched the video, it looks fucked.
Check fuses and connections to the clocks.
Deathoctimus
PostPosted: 12:46 - 26 Apr 2016    Post subject: Reply with quote
yeah get that seat off and poke around.
Shaun
Current Rides Fireblade 900 RRN / DL1000 past: ZX9R B1 / GSX 600F K3 / YBR125
leecurtis89
PostPosted: 12:48 - 26 Apr 2016    Post subject: Reply with quote
ive just bought the bike and it is a genuine fault i think. The previous owner was a decent guy. Real shame. Hope it aint gonna cost me an arm n leg. Bike mechanically is sound.
Deathoctimus
PostPosted: 12:49 - 26 Apr 2016    Post subject: Reply with quote
https://i1377.photobucket.com/albums/ah68/ShaunBPutman/2006HondaCB600F6WiringDiagram001_zps1a066bd6.jpg
2006 but it may help.
Shaun
leecurtis89
PostPosted: 12:56 - 26 Apr 2016    Post subject: Reply with quote
This is great, thanks!
As they are all on the same connection i think something has come loose under the seat (I hope its this, and not a new unit needed!)
leecurtis89
PostPosted: 21:43 - 26 Apr 2016    Post subject: Reply with quote
changed the fuse over to the spare and it sorted it out... Until i looked up after putting my seat back on the bike and it was in a similar state but now with the rev needle at 0. Appears to me to be a bad earth shorting out and blowing the fuse.
There is a gap of 1 year, 91 days between these two posts...
finchy400
PostPosted: 17:09 - 27 Jul 2017    Post subject: Reply with quote
Hi all, sorry to bring up on old post, however i'm having the same problem with the speedo and rev counter although mine is intermittent. Did you confirm this was due to a bad earth in the end?
Jon
fatjames
PostPosted: 13:37 - 28 Jul 2017    Post subject: Reply with quote
Good on you for searching.
Just checked leecurtis89's profile, he hasn't posted since this thread, so is unlikely to reply.
Someone will hopefully be along to help.
Intermittent problems with electronics, sounds like a faulty wire / bad earth.
Have you checked the wiring from the back of the clocks?
finchy400
PostPosted: 14:20 - 28 Jul 2017    Post subject: Reply with quote
Yes i did think that but hoped he might be prompted by an email!
Not checked the wiring from the back of the clocks as yet, that is the weekend job, the manual says to check the live from the battery and ignition plus the continuity of the fuel wire. Will start there and work back.
Here's a video of what is happening in case anyone has any other suggestions: https://youtu.be/3Tw8WZoczUA
Whats strange is that when making that video yesterday it was the first time it had re-set itself multiple times. Normally the lcd screen goes blank and then won't come back until the bike has been left off for a 20 minutes or so.
cheers
cb1rocket
PostPosted: 11:38 - 29 Jul 2017    Post subject: Reply with quote
def. check the wiring to the clocks and it's multi pin connector, possible corrosion
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
The last post was made 6 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 17 - Page Size: 72.8 Kb
