| czakal |
 czakal Nitrous Nuisance
 Posted: 19:15 - 19 Jun 2016 Post subject: E10 schedule: what beyond 2016 |
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/256215/gov-response-motor-fuel.pdf
So according to the latest timetable, the plan to introduce E10 fuel is delayed until after 2016 (and the end of the year is only 6 months away). As I'm buying a new bike and want to be prepared for potential future developments, do we know specifically what is planned for E10 after 2016 or are we going to keep muddling on a bit like we did for the last few years?
Relevant concern for me as I'm getting a budget commuter that might not have the best corrosion resistance against aggressive fuels. |
| Rogerborg |
 Rogerborg nimbA
| czakal |
| andys675 |
 andys675 World Chat Champion
| Alex A |
 Alex A World Chat Champion
 Posted: 14:23 - 20 Jun 2016 Post subject: |
Too right. Despite the apparent compatibility with E10, the first Ducati Streetfighter I had suffered with an expanding tank. It caused the tank to foul the top yoke, lock barrel and the coolant filler, and caused the tank to leak from the overflow. The second one had also expanded but not to the point of causing problems. And that was just with E5 fuel. E10 in the States has caused major problems for Ducati owners with plastic tank models. When faced with a class action, Ducati have replaced them inside and outside of Warranty. But their approach was/is to replace it with a slightly smaller tank of the same material, so when it grew it was less likely to foul other components. A comical bodge!
If Ethanol blended fuel were avoidable, it wouldn't be so much of a problem. But since it doesn't need to be labelled, you just don't know what you're putting in the tank, even if you choose high octane. For that reason, I always tried to leave the Ducati tank as close to empty as possible when I knew it would be sat for a few days or more.
I believe other manufacturers' bikes with plastic tanks are similarly affected (Triumph, Aprilia, etc). I don't think I would buy another bike with a plastic tank because of this problem, unless the deal was so good that I could afford to replace it in the event of problems, or even better, replace it with a steel / aluminium / carbon fibre tank (where such things are available). Then again, why would I want the potential headache? |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:00 - 20 Jun 2016 Post subject: |
| Alex A wrote: | the first Ducati Streetfighter I had suffered with an expanding tank. |
Pre 2009?
Hmm, the Nazi Tractor tank is plastic. I've not heard of any problems with them though, at least not with E10.
I'd blithely assumed that premium / high octane fuel wouldn't be E10, but it turns out that ethanol actually raises octane. At least until it absorbs water, then you're stuffed.
Fortunately both my current engines are undertuned and will run on just about anything with a bit of bang in it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Alex A |
| Alex A |
| Rogerborg |
 Rogerborg nimbA
The last post was made 10 years, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
