| The Artist |
 The Artist Super Spammer
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:37 - 05 Jun 2016 Post subject: |
First check the lever & pivot.
Could be the pivot pin is rusty, or the pin done up too tight.
Also not unknown for the pivot tangs on the master-cyl casting to get dinged and pinch the blade.
Some after-market lever-blades can also be very dire & may have 'cam' that presses on the end of the cylinder that is peculiar.
Next suspect would be the calliper; what state are the pistons in? Are they sticking? If a floating calliper, is the calliper seized on the float pins or sticking.
Drop the calliper & clean
Pull the pads, look for uneven wear - one pad may be down to the backing, opposite not, indicates sticking piston/float
Replace the pads as a matter of course while you're in there.
They could be bad pads, or contaminated or cooked... but basic 'service' aught to sort it.
Probably worth flushing through new fluid & bleeding whilst you are about it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| The Artist |
| The Artist |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Beehive Bedlam |
| Kickstart |
 Kickstart The Oracle
| talkToTheHat |
 talkToTheHat World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| The Artist |
| Islander |
 Islander World Chat Champion
| The Artist |
| rubyhorse2 |
 rubyhorse2 Traffic Copper
| Islander |
| The Artist |
| weasley |
 weasley World Chat Champion
| The Artist |
| rubyhorse2 |
| tom_e |
 tom_e Brolly Dolly
| Tdibs |
 Tdibs Traffic Copper
| The Artist |
 Posted: 16:54 - 08 Jun 2016 Post subject: |
Front single pot disc. I know not to expect it to stop on a dime but there is definitely something not right with it.
Cheers for the halp.  |
| The Artist |
 Posted: 21:48 - 09 Jun 2016 Post subject: |
https://i.imgur.com/qM0sBbw.jpg
https://i.imgur.com/Vjydx3G.jpg
https://i.imgur.com/HUZeHkb.jpg
When I took the seals out, they were pretty shagged. There were very thin slices of rubber sitting behind the piston. It wasn't leaking before as far as I can tell but I have cleaned the caliper up as best I can and reassembled with new seals and new pads. Haven't had a chance to test but will do tomorrow morning.
New brake fluid as well to satisfy rubyhorse2  |
The last post was made 10 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
