| Pete. |
 Pete. Super Spammer
 Posted: 09:01 - 07 Jun 2016 Post subject: Display crashing but card temps ok |
My pc has an annoying habit of crashing the display driver when the room temperature gets moderately warm and the machine has been on some time. It's a modest system (Dell optiplex 755) that is rock stable except for this one issue. The machine runs 24/7 but on warmer days it will sometimes suddenly give a fault where the display corrupts. The control panel reports that the driver has recovered from a fault, but it will keep doing it over and again. Most times I can see enough to use the start button to shut the PC down otherwise I have the power button set to shut down properly. The only thing to do then is leave it off for at least 30mins to let it all cool down thoroughly, then it will be ok. On cooler days there's no problem at all.
Hardware monitor reports reasonable temps. The GPU is passively cooled with heat-pipes and a large sink. The highest temperature I've seen the GPU reported is 54 degrees but it's generally around 51-52. Searches suggest that they are good up into the high 60's low 70's at least.
I'd really like it if I didn't have to rip out this card. I use it with dual DVI monitors and the system is very quiet with the large passive cooler. I suspect I might have an overheating memory module or something. Is there something I can do to turn down the card performance, perhaps by reducing the memory clock speed etc, to reduce internal temps?
Some relevant info:
| Code: | [Display]
Operating System: Windows Vista (TM) Business, 32-bit (Service Pack 2)
DirectX version: 11.0
GPU processor: GeForce 8600 GT
Driver version: 340.52
Direct3D API version: 10
CUDA Cores: 32
Core clock: 620 MHz
Shader clock: 1355 MHz
Memory data rate: 1700 MHz
Memory interface: 128-bit
Total available graphics memory: 1661 MB
Dedicated video memory: 256 MB GDDR3
System video memory: 0 MB
Shared system memory: 1405 MB
Video BIOS version: 60.84.35.00.10
IRQ: 16
Bus: PCI Express x16
Device ID: 10DE 0402 22831682
[Components]
nvui.dll 8.17.13.4052 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.13.4052 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.4052 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.4052 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.4052 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.4052 NVIDIA User Experience Driver Component
nvCplUIR.dll 7.8.760.0 NVIDIA Control Panel
nvCplUI.exe 7.8.760.0 NVIDIA Control Panel
nvWSSR.dll 6.14.13.4052 NVIDIA Workstation Server
nvWSS.dll 6.14.13.4052 NVIDIA Workstation Server
nvViTvSR.dll 6.14.13.4052 NVIDIA Video Server
nvViTvS.dll 6.14.13.4052 NVIDIA Video Server
nvDispSR.dll 6.14.13.4052 NVIDIA Display Server
NVMCTRAY.DLL 8.17.13.4052 NVIDIA Media Center Library
nvDispS.dll 6.14.13.4052 NVIDIA Display Server
PhysX 09.13.1220 NVIDIA PhysX
NVCUDA.DLL 8.17.13.4052 NVIDIA CUDA 6.5.12 driver
nvGameSR.dll 6.14.13.4052 NVIDIA 3D Settings Server
nvGameS.dll 6.14.13.4052 NVIDIA 3D Settings Server |
____________________ a.k.a 'Geri'
| RhynoCZ |
 RhynoCZ Super Spammer
| CaNsA |
 CaNsA Super Spammer
 Posted: 10:51 - 07 Jun 2016 Post subject: |
| Loui5D |
 Loui5D Brolly Dolly
| Pete. |
 Pete. Super Spammer
| RhynoCZ |
| Pete. |
 Pete. Super Spammer
| chris-red |
| orac |
 orac World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 11:51 - 10 Jun 2016 Post subject: |
Follow-up:
Everything's been rock steady now for three days, running at the reduced frequencies (which are the standard frequencies for that class GPU). Core temperature is 2 degrees lower than before, though I think that it was more likely the RAM that was getting over-worked.
I used nvidia system tools to adjust the card frequencies. ____________________ a.k.a 'Geri'
The last post was made 10 years, 98 days ago. Instead of replying here, would creating a new thread be more useful? |
