new wiring loom
therock
PostPosted: 22:17 - 21 Aug 2004    Post subject: new wiring loom Reply with quote
hi i have an nsr125r 1999 and i just wonderd how much it would cost too have a new wiring loom fitted by electrician
robbiehall
PostPosted: 22:22 - 21 Aug 2004    Post subject: Reply with quote
What has happened to the existing one? Cut or butchered by a previous owner, burnt out in a fire/accident? Unexplained electrical problems?
It may be possible to get a 2nd hand one from a breakers.
There is a guy called Ferrett who advertises in Classic Motircycle Mechanics that may be able to help if you just have a problem.
Or if you fancy a go yourself, strip the bike down and splice in new wires and tape it back up again.
Rob
The older I get, the faster I was.
PostPosted: 01:26 - 22 Aug 2004    Post subject: Reply with quote
The most useful guide to DIY bike wiring you will ever read
PostPosted: 00:00 - 23 Aug 2004    Post subject: Reply with quote
Wiring looms new are sometimes not that expensive from the original maker. Fitting them is also not too difficult if you are just taking one off and fitting the new one at the same time.
It you really want to pay an auto electrician then be aware that good ones are rare and thus likely to chargea fair amount of money, and fitting a new loom is some way below their abilities.
What is the problem with the electrics at the moment?
therock
PostPosted: 18:58 - 23 Aug 2004    Post subject: Reply with quote
stinkywheely wrote:
the wiring loom on my bike wont charge the battery and also the power valve is not working the problem started with the ignitoin packing up so i paid for a full lock set still didnt work so i sent it too a mechanic he couldnt sort it so he got his sparky mate too have a look and he got it too start but battery wouldnt charge then then i noticed the power valve wasnt working the sparky sed it needs a new loom i was thinking of selling it cheap or putting new loom on it but now ive just had enough of it as i have now passed my bike test other than that it aint too bad
PostPosted: 21:06 - 23 Aug 2004    Post subject: Reply with quote
My guess would be the regulator / rectifier unit is gone, or possibly the alternator stator. Not that cheap, but neither would be fixed by a new loom.
It should be easy for a decent auto electrician to poke around with a multimeter and check the actual wiring.
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 14 - Page Size: 49.61 Kb
