Author |
chris-red |
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Back to top |
331X2 |
331X2 Crazy Courier
Back to top |
groovylee |
groovylee World Chat Champion
Posted: 15:29 - 01 Aug 2016 Post subject: |
you'll need a connection to the consumer unit. that will need to be connected, via the correct sized cable (6mm will be fine for that size), to one of these:
https://www.screwfix.com/p/mk-2-gang-45a-dp-switch-with-neon-white/15973
or similar, above the worktop somewhere. that then connects (again using 6mm) to one of these:
https://www.screwfix.com/p/mk-45a-cooker-connection-unit-white/16686
under the worktop, which then connects to your cooker, using the cooker cable.
32A breaker will be fine.
all advice to be taken at your own risk, etc etc. ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
Back to top |
Wonko The Sane |
Wonko The Sane World Chat Champion
Back to top |
chris-red |
Back to top |
stinkwheel |
Posted: 17:28 - 01 Aug 2016 Post subject: |
Most houses have a 30A spur with an isolator for the oven. Get an isolator with a socket and you can plug your welder into it (when the oven is off).
Use 6mm sq cable. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
BTTD |
BTTD World Chat Champion
Back to top |
dydey90 |
dydey90 World Chat Champion
Back to top |
MCN |
MCN Super Spammer
Posted: 10:12 - 02 Aug 2016 Post subject: Re: Wiring up a new oven. |
He only needs enough juice flowing to the oven for cooking toasted cheese, it's fine. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
Mark_F |
Mark_F Crazy Courier
Back to top |
Mark_F |
Posted: 10:29 - 02 Aug 2016 Post subject: Re: Wiring up a new oven. |
It doesn't remotely work like that.
The voltage is relatively fixed, the appliance will draw as much current as it needs (providing there is no fault) to work as set.
The fuse is there to protect the wiring. 6mm sq cable is usually rated to around 45amps CCC, so the fuse needs to be rated below that 45amps (to protect the wiring), but can be higher than the normal draw of the appliance. In this case, the appliance may draw a smidge more than 20amps under normal use, thus a 25amp fuse would be appropriate (given that it's the next size up from 20amps).
The power draw of the appliance determines the size of cable required, and the size of cable determines the maximum fuse size (though it is appropriate to reduce the fuse size to suit the appliance). |
Back to top |
chris-red |
Posted: 11:08 - 02 Aug 2016 Post subject: Re: Wiring up a new oven. |
Care to explain? From school I remember
Power/Volts = Current
4900w/230v = 21.3amp
Fuses should always be a bit* more than the maximum draw.
Therefor 25amp seems reasonable.
*(technical term) ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
Back to top |
sickpup |
sickpup Old Timer
Back to top |
Ste |
Ste Not Work Safe
Posted: 12:48 - 02 Aug 2016 Post subject: Re: Wiring up a new oven. |
Cached before any posts get edited. |
Back to top |
stinkwheel |
Back to top |
dodsi |
dodsi Dirty Carny
Back to top |
MCN |
MCN Super Spammer
Back to top |
stinkwheel |
Posted: 14:00 - 02 Aug 2016 Post subject: |
MCN wrote: |
They could use a sniffer for methane.
I recently searched for 'rules' concerning bottle gas installation for mobile home/camper.
It is quite confused some advise it come under Gas Safe and some advise not. A caravan parked at the side of a house/full of family would possibly make a bit of a mess too if it decided to ignite.
I just replaced the hoses on my BBQ and camper no kittens were harmed. |
I did mine with the 6mm plastic coated microbore they use for car LPG systems. Perfect for an LPG hob if you need to use gas bottles.
Then I pressurised it to 120psi and listened for leaks.
Gas safe people don't check for leaks though. They just hook it up and switch it on. I've watched them do it.
I took the gas meter out at my work, blanked the pipe off and wired the tap shut. It was constantly under the feet and we don't use gas. I will assure anyone official who whinges about it that my boss gave me a very stern talking to about it when he found out.
Someone still comes round once a quarter and reads the meter though. Despite it being dumped on the floor in a back room not connected to anything. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
chris-red |
Back to top |
MCN |
MCN Super Spammer
Back to top |
sickpup |
sickpup Old Timer
Back to top |
sickpup |
sickpup Old Timer
Back to top |
chris-red |
Back to top |
sickpup |
sickpup Old Timer
Back to top |
The last post was made 7 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
