Honda S-Wing 2010 F1 Light
astroscope
PostPosted: 11:13 - 21 Jun 2016    Post subject: Honda S-Wing 2010 F1 Light Reply with quote
So I seem to be getting this light now and then. Not always. It's blinks a few times and then I turn of the engine and restart it. Light's gone. Anyone own this bike and could advise/suggest something. I have the Honda Haynes manual for this bike but I think it suggsts taking it to Honda as they have a machine that could read it.
Cheers Thumbs Up
2010 Honda FES S Wing 125
UnknownStuntm...
PostPosted: 12:44 - 21 Jun 2016    Post subject: Re: Honda S-Wing 2010 F1 Light Reply with quote
Cheers Thumbs Up
So, it's actually FI, not F1, FI standing for Fuel Injection. I believe it flashes a number of times to indicate roughly what the problem is too, so count the flashes. It's likely to be something like four flashes, a pause, then four flashes, then a pause etc. To me, this would indicate fault code 4, and so on.
UnknownStuntm...
PostPosted: 12:46 - 21 Jun 2016    Post subject: Reply with quote
https://www.vfrdiscussion.com/index.php?/topic/16-fi-light-how-to-read-error-codes/
Help at all?
astroscope
PostPosted: 14:08 - 21 Jun 2016    Post subject: Reply with quote
The trouble is the last time the F1 or FI light appeared was a couple months ago. So i now need to wait for it to appear again and then count the flashes. I was thinking of just putting some Blu Tak on the dash where the FI light is. So annoying! Very Happy
cb1rocket
PostPosted: 20:01 - 21 Jun 2016    Post subject: Reply with quote
The haynes manual actually covers the fuel injection system and how to trouble shoot fault codes. Its in the manual with a list of codes. Bridging a connector near the battery will show up the error codes for you
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
astroscope
PostPosted: 09:41 - 22 Jun 2016    Post subject: Reply with quote
OK, it's happened again today. Sad
Nine flashes and then a second or so pause, then nine flashes again and then pause and so on.
I turned off the engine and cranked her up again and then flashes gone. No FI light all the way to a 12 mile commute.
charlie74
PostPosted: 10:20 - 22 Jun 2016    Post subject: Reply with quote
seems you have a duff sensor in one of the systems...
choice if the bike is running fine. carry on wait till fault developes.. or get it fixed
Evil Hans
PostPosted: 10:36 - 22 Jun 2016    Post subject: Re: Honda S-Wing 2010 F1 Light Reply with quote
Doh, I always thought it stood for Fault Indicator. You live and learn.
astroscope
PostPosted: 10:41 - 22 Jun 2016    Post subject: Reply with quote
Might just have a look at the fuel injection system in the haynes manual and see if it can be overhauled/cleaned.
PostPosted: 11:34 - 22 Jun 2016    Post subject: Re: Honda S-Wing 2010 F1 Light Reply with quote
I thought it does as well. One of my Goldwings had it flash when the speedo sensor died. Nothing to do with fuel injection.
Triumph Trophy Launch Edition
charlie74
PostPosted: 11:37 - 22 Jun 2016    Post subject: Reply with quote
try running a tank or 2 of NON supermarket superunleaded through it, shell and esso stuff has cleaner additives in it, not sure about supermarket stuff
astroscope
PostPosted: 11:50 - 22 Jun 2016    Post subject: Reply with quote
I've always filled up from Tesco as it's cheaper Smile
Just filled her up yesterday on the way home.
UnknownStuntm...
PostPosted: 12:20 - 22 Jun 2016    Post subject: Re: Honda S-Wing 2010 F1 Light Reply with quote
Holy crap you might just be right and I haven't got a Honda manual to check against! Embarassed
cb1rocket
PostPosted: 11:43 - 23 Jun 2016    Post subject: Reply with quote
9 blinks is the IAT sensor. (Intake air temperature) I have the offical workshop manual.
It's a sensor that integrated inside the ecu throttle body, so the only way to fix is replace with another. There are no wires as it's an all in one unit
astroscope
PostPosted: 13:16 - 23 Jun 2016    Post subject: Reply with quote
I've just been on the phone with Honda parts and the IAT sensor is built into te throttle body. It's costs a wopping £545 Shocked Shocked Shocked
I don't think my bike is worth Sad that much
Minty
PostPosted: 13:25 - 23 Jun 2016    Post subject: Reply with quote
There's a couple on eBay from Poland.
My fingers smell of your mum.
astroscope
PostPosted: 14:14 - 23 Jun 2016    Post subject: Reply with quote
I'm actually thinking about opening up the whole throttle body and giving it a good clean with carb cleaner. Have the haynes so it might help.
There maybe some crud inside the throttle body could be causing the sensor to give off some incorrect readings.
cb1rocket
PostPosted: 19:29 - 23 Jun 2016    Post subject: Reply with quote
No just don't its a sealed unit and not designed to be taken apart as its all set at the factory. Trust me your mess it up and render your bike useless.
astroscope
PostPosted: 11:52 - 24 Jun 2016    Post subject: Reply with quote
Sad I don't wanna spend £500 quid.
I didn't get any FI light today. All seemed fine strangely.
astroscope
PostPosted: 12:06 - 24 Jun 2016    Post subject: Reply with quote
I'm looking at the ones from Poland. Not a bad price considering how much saving is made.
Just a bit scared ordering from Poland.
cb1rocket
PostPosted: 23:14 - 25 Jun 2016    Post subject: Reply with quote
I do actually have one spare but not willing to part with it, to be honest your bike runs so i would ignore it.
swingymike
PostPosted: 12:19 - 29 Jul 2016    Post subject: Reply with quote
Astroscope, how has the story ended?
I have 2011 S-Wing with a similar problem, and looking forward to fix it.
FI indicator lights up after couple mins of riding, after I stop it blinks nine times and repeats. No other symptoms occured.
There is a gap of 3 years, 83 days between these two posts...
hayes2865
PostPosted: 18:37 - 20 Oct 2019    Post subject: Hi Reply with quote
I do not suppose you have a copy of the workshop manual
Honda 2013 S Wing 125cc
cb1rocket
PostPosted: 13:01 - 21 Oct 2019    Post subject: Reply with quote
only paper copy, Haynes do a manual for it too which is equally as good.
hayes2865
PostPosted: 17:49 - 04 Nov 2019    Post subject: Reply with quote
Did you ever fix this problem? I have 9 blinks now
The last post was made 6 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 124.94 Kb
