Needle bearings.
Kawasaki Jimbo
PostPosted: 19:53 - 10 Jul 2016    Post subject: Needle bearings. Reply with quote
I fitted some £6 needle bearings to the swing arm linkage, packed them with grease and then slid the sleeve in, but the needles kept getting dislodged. I tried using a rubber hose ahead of the sleeve to support the needles as the sleeve goes in, but still no good. Next I paid £17 (£12 elsewhere, I've since learned) for Kawasaki bearings and noticed that the needles are retained by a cone added to the length of each needle, so they won't fall out.
In the picture the flat-ended needle on the left has fallen out of the bearing. The bearing on the right has cone-end needles which means they are retained in the shell. I'll be fitting it later. The cone-end needle on the right came out of an old bearing but only by hammering the shell, and is shown just as an example.
Now I just need to remove the cheap bearings and fit the decent ones. Lesson learned.
Meatybeaty
PostPosted: 20:13 - 10 Jul 2016    Post subject: Reply with quote
Hi , I'm a bit cheap myself so I always look around like these Thumbs Up
https://simplybearings.co.uk/shop/p8257/HK1816-Drawn-Cup-Type-Needle-Roller-Bearing-With-Two-Open-Ends-18x24x16mm/product_info.html
Kawasaki Jimbo
PostPosted: 21:01 - 10 Jul 2016    Post subject: Reply with quote
Meatybeaty wrote:
Looking at the technical section these needles do appear to have machined ends suggesting they'll be retained in the housing. My point is that I now know what to look for.
Raffles
PostPosted: 21:29 - 10 Jul 2016    Post subject: Reply with quote
I've never understood why so many people worship at the alter of Wemoto and similar outfits. They're no better than snake oil salesmen.
The last post was made 10 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 40.38 Kb
