NSR125R Fork Oil Seals and Sprocket Change advice needed
damo
PostPosted: 17:43 - 25 Aug 2004    Post subject: NSR125R Fork Oil Seals and Sprocket Change advice needed Reply with quote
Hi, I'm having a problem in finding out what fork oil I should be using. One of my local dealers tells me that I should SAE 10w fork oil. Another tells me I should use TQF fork oil.
Any one have any ideas.
The other thing is I'm about to change my chain and my front and rear sprockets as they have worn out. What I'd like to know is what no. teeth sprockets should I use front and back.
At the moment my NSR125R has a 13T Front and a 35T rear, with these I find that I blast through the gears very quick. Should I change to a 14T front and stick with the 35T rear or change to a 36T.
Any comments would be useful.
Thanks Damo.
mr jamez
PostPosted: 18:53 - 25 Aug 2004    Post subject: Reply with quote
The honda manual specifies ATF fork oil, till it is 130 mm up the fork, measure from the top obviously, pump it before measuring. Put the springs in after you have filled it with oil.
EDIT: just did a search and came up with this on the sprockets:
NSR Sprockets 14T-front 36T-rear (125Rmodels)
NSR Sprockets 13T-front 35T-rear (125F,S,RV,RS Models)
alains
PostPosted: 20:27 - 25 Aug 2004    Post subject: fork Reply with quote
i use SAE 20W which is a grade higher . the suspension is a bit harder but fine . i think for a nsr125R de-rectricted 14X39 is the best final transmission
the worst day fishing is better than the best day working
Skvara
PostPosted: 22:04 - 25 Aug 2004    Post subject: Reply with quote
I use SAE 10w and it's great!!!
There is a gap of 16 years, 42 days between these two posts...
RodRides This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
xX-Alex-Xx
PostPosted: 17:04 - 03 Oct 2020    Post subject: Re: Changing Sprockets How to... Reply with quote
RodRides wrote:
Step by Step on changing sprockets.
https://youtu.be/7roUwXE9sOE
Dude stop bringing back old threads FFS
DILLIGAF
blurredman
PostPosted: 17:50 - 03 Oct 2020    Post subject: Reply with quote
16 years is the oldest i've seen revived.. Shocked
The last post was made 5 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 55.51 Kb
