| fazer_kid86 |
 fazer_kid86 L Plate Warrior
| Fizzoid |
 Fizzoid World Chat Champion
| arry |
 arry Super Spammer
 Posted: 14:34 - 12 Sep 2016 Post subject: Re: First time biker |
| fazer_kid86 wrote: |
Also, apart from the style what is the main difference between a scooter and a more sporty looking bike? Is it just a case of preference? All I want is something that will get me into the city quickly and cheaply. Thanks in advance for your replies.
Cheers,
Pete |
Scooters tend to be automatic; left lever rear brake, right lever front brake - throttle to go. Otherwise known as twist and go.
'More Sporty looking bikes' is a bit for 125's but yeah, motorcycles proper have gears, so you'd be using left hand to control left lever which is a cable operated clutch, left leg to change gears through the box, and right leg to operate rear brake. Everything else same as scooter.
125 Motorcycles can be rugged commuter types like a YBR125 or CG125, or pretty much the same motorcycles with a few tweaks and a very expensive plastic frock which turns them into 'supersports' bikes - see Yamaha R125 for reference. For commuting work, you're better off with something that's more commuter friendly - so a YBR125 would be much more suited as it'll be cheap if you drop it, is less likely to be stolen, and can be bought much cheaper outright. It also has a better turning circle and a less aggressive riding position putting less weight on your wrists and back in traffic.
Scooters tend to be a little more practical as they have load space under seat, but somewhat boring with no gears and small wheels that don't do handling very much good at all.
As for commuting into London. It's generally not a lot of fun but can be a very practical option assuming you don't need a perfectly pressed suit and tie every day for your role. What you will have to bear in mind is that you'll get hot in summer (need a shower when you get there possibly?) and cold in winter (and treacherous, you'll be commuting in the dark for a good few months assuming a 9 to 5 job and the roads when wet / icy etc aren't nice).
You'll need to factor the right gear into your budgeting. That will include of course a decent security chain (in London without one, bad idea) which is £100+ usually, and the right gear to keep you safe / warm / cool / dry depending on conditions.
Finally yes, you just need a CBT to ride a 125 on L plates, but you will have no motorway or pillion carrying ability so bear that in mind if they're important. You have to redo your CBT every 2 years, or pass your full motorcycle test and avoid the repeated L Plate buggery. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:30 - 12 Sep 2016 Post subject: |
As above. A scooter will make better use of its available meagre power without you tap-dancing up and down the gearbox looking for a perfect ratio that isn't there. For commuter practicality, you can't beat them.
However, I lasted one winter on my Burgman 400 (during which it did an excellent job) before sacking it off because, oh my allah, so dull. So dull.
It's really up to you. You'll likely be given the option of doing your CBT on either a twist-and-go (probably a 49cc moped) or a 125cc geared bike. If you fancy giving gears a go, take the opportunity.
Legally, it doesn't matter what you do the CBT on though. You can do it on a twisty-ped, then ride away on a geared 125 (technically if you were accompanied by a certified instructor, you could ride away on a Fireblade). ____________________ Biking is 1/20th as dangerous as horse riding.
| fazer_kid86 |
| Val |
 Val World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:13 - 12 Sep 2016 Post subject: |
+1 on both of those. Yes, they look daft, but they work very well indeed. Bikers who don't ride through the winter will scoff, then weep sadly into their cocoa and dream of April. ____________________ Biking is 1/20th as dangerous as horse riding.
| Derivative |
 Derivative World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| Nobby the Bastard |
| grr666 |
 grr666 Super Spammer
 Posted: 21:10 - 12 Sep 2016 Post subject: |
Pick one with 16" wheels.
Just got one of these for my mrs.
https://moto.zombdrive.com/images/yamaha-xenter-125-motogp-2014-1.jpg
Loathed as I am to admit it, it's quite a giggle to ride. Monoshock rear because racing scooter  ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| Derivative |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:49 - 13 Sep 2016 Post subject: |
I'd go Pragmasis, until Almax apologises for spamming BCF. NEVER FORGET. ____________________ Biking is 1/20th as dangerous as horse riding.
| fazer_kid86 |
| Derivative |
The last post was made 10 years, 3 days ago. Instead of replying here, would creating a new thread be more useful? |
