| nschadle |
 nschadle L Plate Warrior
| colink98 |
 colink98 Could Be A Chat Bot
 Posted: 14:48 - 29 Sep 2016 Post subject: |
Metal on metal would be more of a grinding noise as opposed to a squeak.
you should be able to eye ball the pads while still in the calliper and your looking for how much break material is left on the pad.
quick goggle shows these
https://www.ebay.co.uk/itm/like/311697976119?lpid=122&chn=ps&adgroupid=27378760866&rlsatarget=pla-181484354946&adtype=pla&poi=&googleloc=9045906&device=c&campaignid=620865095&crdt=0
the lines down the centre are wear markers.
once the pads are worn past the wear maker its time to consider replacing.
if you let it get to metal on metal then you risk damaging the disks which is far more expensive than a set of pads.
no harm in giving it a good clean.
put some copper slip on the back of the pads. ____________________ PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week. |
| Evil Hans |
 Evil Hans World Chat Champion
| Baffler186 |
 Baffler186 World Chat Champion
 Posted: 16:53 - 29 Sep 2016 Post subject: |
Youtube will tell you how brakes work, and how to maintain them, and check them. Doesn't really matter what bike, the principle is the same. If your pads still have meat on them, dismantle, inspect, clean, thoroughly squirt off any contact points with brake cleaner. Then grease (copper slip or similar) the back of the pads (not the front, duh).
The grease on the back of the pads should prevent squealing but you should check and clean (or replace if necessary) the other bits - you do need to maintain brakes other than just changing pads if they wear. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
| andyscooter |
 andyscooter World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:46 - 29 Sep 2016 Post subject: |
Buy a work-shop manual and a pair of new brake pads.
Be VERY careful, to clean the caliper and the piston and all around it thoroughly with hot soapy water and a stiff brush, before you start taking anything apart; when brake pads wear they leave dust around everything, which when it gets wet, usually traps moisture and makes it acidic, promoting corrosion, that can make bits stick or squeek... but, hint is its time for some maintenence.
DONT try pushing the piston straight back into the caliper to get the new brake pad in.
Make sure its as clean as you can get it, and that the piston itself isn't pitted or corroded where its been sat out in the elements, collecting brake dust as the brake pad has worn away... pushing it back in if its dirty or corroded is a recipe for later brake failure when the rough piston will be wearing on the seal that keeps the fluid in.
Make sure its all clean as possible; and grease the pins that the caliper moves sideways on, pilling the back of the caliper and inside brake pad against the disc as the piston pushes outside pad against the other side of the disc; and the back of the new pads, LIGHTLY with coppa grease.
Check the manual for correct fitment of the 'antirattle' clip if there is one, and the pad retaining pins.
Then ponder how much else may benefit from a little preventative maintenence....
PS: I say buy new pads; as they are cheap; and if you are going to go to the effort of stripping and cleaning, you may as well do the job once and be done, rather than try and eek out a few pennies more life from whats a £10 service item, you are likely going to have to buy at some point and do the job over. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 9 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
