Suzuki GSX400T flat tracker project – electrical problems
Bubblegumhead
PostPosted: 21:02 - 21 Oct 2016    Post subject: Suzuki GSX400T flat tracker project – electrical problems Reply with quote
Hi All,
I have an '83 GSX400T, which I've been modding into a flat tracker part time over the last year or so. Apart from wanting to do some respraying, it's pretty much done, and is running well.
However, I have some electrical problems, and this has never been a strong point of mine. All the lights have been replaced, as has the battery.
The problems are: -
The tail light (which is LED) comes on but not the brake light. So I'm thinking the rear brake switch is defective, maybe? Or a bad ground somewhere?
The tacho isn't working. I have checked the tacho cable by removing it from the clock and running the bike, and that appears ok.
Please note that the headlight and horn are fine, and it starts up with no problem. The indicators are not flashing, but I think that is due to the power output of the bulbs being too low for the original flasher relay, so have ordered a suitable replacement.
I have been scouring various threads and sites but have not found a definitive answer for either issue.
So, I would appreciate some guidance. I have a multimeter, but have never got to grips with using it properly.
Thanks in advance.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:25 - 21 Oct 2016    Post subject: Reply with quote
Aside from the fact that cutting the rear subframe off doesn't a flat-tracker make, don't ask on here about electrics UNLESS you have a multimeter.
You can buy one for about £6.
Triumph Sprint ST 1050
Bubblegumhead
PostPosted: 21:35 - 21 Oct 2016    Post subject: Reply with quote
I do have a multimeter...
Nobby the Bastard
Harley Gaydar
PostPosted: 21:48 - 21 Oct 2016    Post subject: Reply with quote
Test the fucking switch then.
Bubblegumhead
PostPosted: 18:05 - 22 Oct 2016    Post subject: Reply with quote
Right... checked the switch and continuity to all wires leading to the light and all ok. So had a closer look at the light... turns out one of the wires had broken off the circuit board. So after a bit of hassle with soldering, have managed to sort it.
I would still appreciate some constructive advice on how to check the tachometer.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:29 - 22 Oct 2016    Post subject: Reply with quote
Assuming that the tacho is run off the gearbox (which would be weird for a modern bike, my 26 year old exup is competely electrical) if the cable is turning and has a good square shape to it, the clock is broken.
The last post was made 9 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 46.3 Kb
