map |
map Mr Calendar
Posted: 11:46 - 27 Aug 2004 Post subject: Winter storage query? |
A bit early I know but thought I'd ask while I remember
I'm confused on the draining of fuel. There is a recommendation to drain the carbs (see here for example).
However, other advice I've been told is that an empty carb can result in cracked/holed diaphragms.
So which is it?
For myself I was thinking go with fuel stabiliser and run the engine every 3-4 weeks. I think Yamaha used to do a bottle of stabiliser, have to get down to the dealer and see if they still do ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger? |
Big Pete |
Big Pete Spanner Monkey
map |
map Mr Calendar
Big Pete |
Rory |
Rory Traffic Copper
Posted: 13:46 - 27 Aug 2004 Post subject: |
Once you've prepped and stored the bike, don't start it up unless you're going to go for a ride, and thrash it if you do that. As Pete says, you need to make sure and boil off any water vapour. ____________________ My Old CBR400RR | Bike Oil FAQ | Petrol FAQ |
map |
map Mr Calendar
Guest |
Guest Brolly Dolly
ZRX61 |
ZRX61 Victor Meldrew
Posted: 18:31 - 28 Aug 2004 Post subject: |
They sell a fuel stabilizer called Sta-Bil (oddly enough..) Ya just mix in the required amount when ya tank is full, ride around the block a couple of times to get the stuff into the carb & then park it up.
Saves throwing away an entire tank full of gas at $7/gallon...
Ya should be able to get it where they sell lawn mowers or jet ski's etc... & no need to drain the carb...
...change the oil.. & try to park it with the tires off the ground so no flat spots from sitting for months
If ya want to prevent rust on it get a can of BoeSheild T9 & spray it on EVERYTHING except the brake rotors, seat & tyres. It comes off with HOT soapy water. |
The last post was made 19 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
