Sportster rocker cover leak
A100man
PostPosted: 16:21 - 22 Oct 2016    Post subject: Sportster rocker cover leak Reply with quote
A friend of mine has a H-D Sportster which is weeping from the rear left hand corner of the rear pot. the cover looks to be held on by just 4 x M6 (or similar) sized Allen bolts, but is there more to it ? Not much sign of a gasket either so is it just some hylomar needed or a paper gasket..
I was surprise to see just 4 fixings on what is a fairly hefty lump of alloy.
Any advise gratefully received.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:43 - 22 Oct 2016    Post subject: Re: Sportster rocker cover leak Reply with quote
The 4 fixings are just to align it, gravitational attraction keeps it in place.....
Triumph Sprint ST 1050
jaffa90
PostPosted: 22:42 - 22 Oct 2016    Post subject: Reply with quote
I would check the gasket and any breather/ pressure that could effect it.
Fisty
PostPosted: 09:38 - 23 Oct 2016    Post subject: Reply with quote
The oil is escaping because it's ashamed to be in a Harley.
Fatter and faster than Fret
Robby
Dirty Old Man
PostPosted: 12:54 - 23 Oct 2016    Post subject: Reply with quote
They have a two part rocker cover. The upper cover is just held on by four small bolts and has a small rubber gasket, the lower is held on by more bolts and has a proper gasket.
A100man
PostPosted: 17:48 - 23 Oct 2016    Post subject: Reply with quote
Thanks chaps for all the feedback. Believe it or not the owner is a 5' 2"
sixty-ish year old lady. So not your usual Harley poseur Smile .
I spotted the unusual two part construction and I think (hope) it's just the top joint leaking.
Presumably the four allen bolts on the top are some imperial or AF size.
The last post was made 9 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 47.1 Kb
