| Can the plane take off? |
| Yes |
47% |
[ 34 ] |
| No |
52% |
[ 38 ] |
| Total Votes : 72 |
| Lord Percy |
 Lord Percy World Chat Champion
| Lord Percy |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 10:38 - 13 Oct 2016 Post subject: |
Air travel speed from jet pressure stays the same...so it can take off  ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| Loui5D |
 Loui5D Brolly Dolly
 Posted: 10:40 - 13 Oct 2016 Post subject: |
The plane will only take off due to lift, this requires a moving air current to form a pressure difference underneath the wing.
No movement of air = no lift. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 10:41 - 13 Oct 2016 Post subject: |
The plane won't take off. Any forward thrust will be counteracted by the conveyor, so there's no airflow over the wings to generate any lift. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Lord Percy |
| Lord Percy |
| The Shaggy D.A. |
| Loui5D |
 Loui5D Brolly Dolly
| Hetzer |
 Hetzer Super Spammer
| Lord Percy |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
 Posted: 10:56 - 13 Oct 2016 Post subject: |
On a normal aircraft there's no limitation on the wheels rotation during takeoff. The conveyor would be acting as a brake, so the plane remains stationary while the engines do their best to overcome this. They can't so no lift is generated by the wings and so on until someone's head is bleeding with the thought of this.
And that conveyor would need to be driven by some fuckoff jet engines, with bearings made of supercooled magnets that would most likely still assplode after a few seconds real work.
TL;DR: stop reposting nonsense.  |
| Hetzer |
| Lord Percy |
| angryjonny |
 angryjonny World Chat Champion
 Posted: 11:00 - 13 Oct 2016 Post subject: |
| The Shaggy D.A. wrote: | | You wrote: | The conveyor belt is designed to exactly match the speed of the wheels, moving in the opposite direction. |
The plane will remain stationary. |
I would argue the following:
The wheels do not drive the plane. The engine thrust does. The wheels are there simply because its better than the plane scraping its belly along the ground. The plane can move forward just as easily (some minor friction ignored) on the moving conveyor as it could on a regular runway.
However, the key point is "The conveyor belt is designed to exactly match the speed of the wheels".
This changes everything. Because:
Assume the plane starts doing 1mph.
(1) When the plane does 1mph, the wheels turn at the equivalent of 1mph
(2) The conveyor, then, by design, does 1mph. At this point the plane itself is still doing 1mph but the wheels are now doing the equivalent of 2mph to counter the moving conveyor.
(3) So the conveyor, as designed, then speeds up to 2mph, to match the wheels. As the plane does 1mph the wheels are now doing 3mph. So the conveyor speeds up again. The wheels are always trying to do 1mph more than the conveyor. The conveyor is always accelerating to catch up.
(4) This process continues. The conveyor does 100 mph so the wheels do 101. The conveyor does 1000mph so the wheels do 1001. Eventually something gives up, probably the conveyor. It disintegrates, parts fly out and damage the plane. Now it can't take off.
TL;DR - as soon as the plane starts moving the conveyor goes faster and faster until it implodes.
| Aceslock |
 Aceslock Spanner Monkey
 Posted: 11:02 - 13 Oct 2016 Post subject: |
It wont take off because there is no wind resistance to lift the wings. It will probably nose dive when the conveyor blows up  ____________________ Previous Bike: Skyjet SJ27
Sold: Yamaha YZF 600 R Thundercat. Sold: ZX636R
Current bike: R1 14B (Beast) |
| Lord Percy |
| Loui5D |
 Loui5D Brolly Dolly
| Hetzer |
 Posted: 11:06 - 13 Oct 2016 Post subject: |
| angryjonny wrote: |
The wheels do not drive the plane. The wheels are there simply because its better than the plane scraping its belly along the ground. The plane can move forward just as easily (some minor friction ignored) on the moving conveyor as it could on a regular runway.
(2) So the conveyor, by design, does 1mph. At this point the plane is still doing 1mph but the wheels are now doing the equivalent of 2mph to counter the moving conveyor.
(3) The conveyor, as designed, then speeds up to 2mph. So as the plane does 1mph the wheels are doing 3mph. So the conveyor speeds up.
TL;DR - as soon as the plane starts moving the conveyor goes faster and faster until it implodes. |
That's pretty cockeyed. For the conveyor to impart enough friction to the wheels, such that the friction can overcome the thrust from the engines, it would have to be doing a billion RPM. If the 'conundrum' is to be regarded as a realistic conjectural event the conveyor has to be assumed to be operating within realistic parameters.
innit. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| angryjonny |
| Hetzer |
 Posted: 11:11 - 13 Oct 2016 Post subject: |
Having just re-read the OP's picture, I've decided it's bollocks from the get-go, it makes no sense. 'Matching the speed of the wheels' is non-sensical and the author of the question should be designated a muppet.
| The Shaggy D.A. |
 Posted: 11:13 - 13 Oct 2016 Post subject: |
| Hetzer wrote: | Imagine instead a rope attached to the front of the plane, pulling it. Do you think the plane won't be pullable? |
Depends. If you yourself are not on the conveyor, then yes the plane will move, relative to the air it needs to generate lift. But, if you are on the conveyor too, then the distance between you and the plane will change, but it will remain stationary, relative to the air - no air flow, no lift.
| Quote: | The wheels don't provide a static force, they are independent of any force moving the plane (other than the tiny amount of friction from the bearings).
Or imagine instead the plane with engines off. If you start the conveyor very gently you'll get the plane to move backwards on the conveyor, but start it fast enough to overcome the initial friction from the wheels and the plane will barely move backwards, it's wheels will spin instead. Now start the engines and go full-thrust, the plane will move forwards minus that tiny amount of friction from the wheels. |
The plane will move forward in relation to the conveyor, but the conveyor is moving the plane backwards at the same speed. If the take-off speed is (say) 100mph but the conveyor is going in reverse at 100mph, where's the airflow for the lift coming from? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| STONEY! |
 STONEY! Brolly Dolly
| angryjonny |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:15 - 13 Oct 2016 Post subject: |
Conservation of momentum will move the plane forwards relative to the ground and take off every 'ZIG'. The wheels will simply spin faster than they would if the treadmill wasn't there.
You need to add two pterosaurs for stability though.
https://i2.wp.com/imgs.xkcd.com/blag/sauropod.png ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 9 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
