| SuperMike |
 SuperMike Scooby Slapper
| WD Forte |
 WD Forte World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 18:27 - 03 Dec 2016 Post subject: |
As above.
Charging systems vary in how much power they can supply. A guy on here had a VFR400 (NC30) which couldn't really support heated grips with the lights on (not sure if the bulbs were standard), etc. Long journey at night and it slowly flattened the battery.
You are probably fine with both heated grips and gloves running from the bike. I did a fair few times on a ZZR600. But if you are doing short journeys with a lot of slow speed riding / just sitting idling then you could have more problems.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| G |
 G The Voice of Reason
| SuperMike |
| Kickstart |
 Posted: 18:54 - 03 Dec 2016 Post subject: |
I did use both at the same time.
But it totally depends on your model of bike. Gets a bit more difficult to work out with modern bikes as there are some standard components which will draw a substantial amount of power (eg, fuel pump on an injected bike). At a guess the gloves and grips combined will pull about 5~6 amps, so about 70 watts.
And the amount of power the charging system provides will vary greatly with revs.
| ADSrox0r |
 ADSrox0r World Chat Champion
| SuperMike |
The last post was made 9 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
