Suntan Sid |
Posted: 13:49 - 01 Mar 2017 Post subject: |
We’re in the process of moving house, the new house will require some work, so I bought myself a 10” table saw, I’m going to replace the table and build it into a bench/cabinet, got to build a shed first though!
I’m marking time at the moment, most of my stuff is packed away, so with nothing to do I thought I’d buy some old hand tools to restore.
My first purchase was an old Stanley No.4 smoothing plane, (not my photo but it’s the same plane):-
https://www.handplane.com/images/StatSheets/Stanley/4/StanleyNo.4Plane3-Big.jpg
This didn’t need much work, a bit of rust removal, some general cleaning and oiling, the two main problems with it were the rear handle was broken and it needed sharpening and setting up.
The handle glued back together easily, so next up was sharpening!
I sharpened the blade using 120 and 240 grit emery paper, mounted on a piece of glass and finished it off by using metal polishing compound on a piece of hardwood, following Paul Sellers method, I haven’t made a leather strop yet but I got it sharp enough and got a good edge on the cap iron!
My second purchase was a 16” wooden jack plane, like this, (not my photo but it’s the same plane):-
https://thumbs2.picclick.com/d/l400/pict/262827047769_/16-Antique-wooden-Jack-Plane-by-Mathiesons-of.jpg
Got it for £16 inc. p&p, It was in need of some TLC.
First thing I did to this was to flatten the bottom, started of with 80 grit sandpaper mounted on glass and went through the grits down to 240. I then checked it for square and finished the process off using the No.4 plane I’d refurbed.
Next up the handle wasn’t secure, I glued it in and for added security put a screw in there!
The cutting edge of the blade on this was not good, had a chip out of one side and was not ground square across the blade.
I bought a pound shop whetstone, got the blade back to square, got rid of the chip and got back to a 25 degree angle, then I followed the same process as before to sharpen it!
It’s all set up now and it works great.
I also managed to get a couple a couple of Stanley ‘Handyman’ No.4 planes, the most expensive was £2.20! Anyway, these are not as well specced as the Stanley No.4, they have plastic handles and there is no adjustment for the frog plate. Having said that once I refurbed them they worked just as well.
I got three old, wooden handled, wood chisels, a ¼ inch, a ½ inch bevelled and a ½ in mortise and gave them a good clean and polish.
The cutting edges and bevels were not good on these, so I invested in one of these:-
https://i232.photobucket.com/albums/ee316/paulchapman_photos/Honing/Eclipseguide2.jpg
Got the correct bevels back using my cheap ass whetstone and then sharpened them up!
What have I been doing with these tools, well for practice I’ve been cutting and planing some of the wood burner logs down to perfectly square stock, which is pointless but surprisingly satisfying!
Haven’t got access to my camera at the moment so the photos are all just grabs off the web! ____________________ "Everybody needs money, that's why they call it money!" |
Ribenapigeon |
Ribenapigeon Super Spammer
mentalboy |
mentalboy World Chat Champion
ScaredyCat |
ScaredyCat World Chat Champion
Suntan Sid |
ScaredyCat |
ScaredyCat |
DrDonnyBrago |
DrDonnyBrago World Chat Champion
ScaredyCat |
Posted: 12:15 - 18 Mar 2017 Post subject: |
Rutlands seem to have a bit of a sale going on https://www.rutlands.co.uk/pp+hot-deals+deals if anyone is interested.. ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
Suntan Sid |
ScaredyCat |
Posted: 19:44 - 18 Mar 2017 Post subject: |
Suntan Sid wrote: |
I went for this one:-
https://www.machinemart.co.uk/p/fox-f36-527-10-table-saw-230v/
Didn't pay the Machine Mart price, it came in at £256 inc. P&P.
It's not belt drive but it's all I could justify spending the money on.
The reason I went for the 10" blade, I'm going to build this saw into a cabinet and I will be making my own table, fence etc., to fit over the existing table.
If I use 18mm ply for the new table then make a cross cut sled I would be losing between 30 -36mm of cutting depth.
An 8" blade has a cutting depth 55 - 60mm, the 10" blade has a cutting depth of 80mm, so losing the 36mm isn't too bad! |
Ok, makes sense.
Are the t-track/mitre slots 3/4" (19mm) or some random not standard size? How sturdy/accurate is that fence? Those blue pads look like they're extensions, do all 3 pull out?
I'm looking at getting a thicknesser and a table saw (separate units ) - that would allow me to prep wood rather than buying PAR that's twisted/warped and with those two I wont need a jointer which, judging by the reviews on all but the >£600, are trash anyway.
Space is limited so a 'lunchbox' style thicknesser and a fairly portable (even if it requires a trolley) table saw are the requirements. Jigs aplenty! ____________________ Honda CBF125 ➝ NC700X
Suntan Sid |
Posted: 22:24 - 18 Mar 2017 Post subject: |
ScaredyCat wrote: | Are the t-track/mitre slots 3/4" (19mm) or some random not standard size? |
They're non standard, can't measure them at the moment. it's all packed away. However the T track slots do not match the T track bar well enough, there's a lot of play, so not accurate enough!
ScaredyCat wrote: | How sturdy/accurate is that fence? Those blue pads look like they're extensions, do all 3 pull out? |
Out of the box, the fence did not line up with the blade, however, it's easy enough to shim the fence with some thin pieces of card to line it up. TBH, I haven't had chance to use it, much, but I don't think the fence is stable enough, when locked in position it does flex a bit. If I was going to use it as it is I'd make my own fence and eliminate the flex.
Yes the blue parts are extension tables and they pull out to the maximum dimensions in the product description. They are sturdy and if I wasn't putting mine into a cabinet I'd say they were definitely up to the job!
I'm not particularly bothered about it's short comings, I'm confident I can build a lot of them out when I get my workshop sorted!
ScaredyCat wrote: | I'm looking at getting a thicknesser and a table saw (separate units ) - that would allow me to prep wood rather than buying PAR that's twisted/warped and with those two I wont need a jointer which, judging by the reviews on all but the >£600, are trash anyway.
Space is limited so a 'lunchbox' style thicknesser and a fairly portable (even if it requires a trolley) table saw are the requirements. Jigs a plenty! |
There are videos showing you how to, roughly, joint timber on a table saw, Izzy swan has one, once you've roughed it with the table saw you could hand plane it
One of our ideas for our new house was to have an engineered wooden floor in the hall, I'd like to do it myself, if we do I'll get a thicknesser!
As for a jointer, I've got an electric plane and, when time permits, I'm going to have a go at making a small jointer with it, there are a few videos on youtube showing you how! ____________________ "Everybody needs money, that's why they call it money!" |
ScaredyCat |
Posted: 10:30 - 19 Mar 2017 Post subject: |
Suntan Sid wrote: |
As you say you can use a table saw to joint the edges ( https://www.youtube.com/watch?v=vrYjc3G1vgo ) you can also use a thicknesser to joint the faces. ( https://www.youtube.com/watch?v=OK5CxqYmUSo. So I figure you could get away without a 'proper' jointer. I'd rather put that money towards other tools.
Suntan Sid wrote: |
As for a jointer, I've got an electric plane and, when time permits, I'm going to have a go at making a small jointer with it, there are a few videos on youtube showing you how! |
Yeah, Izzy Swan does one for a hand planer ( https://www.youtube.com/watch?v=3f_8NF74DyI ) but it does seem like a lot of effort and considering that, unless you buy your wood cut to size and it never twists or warps or changes in any way then, you're going to need a thicknesser anyway which will do the jointing job too.
I've also looked at building a cyclone system ( https://www.youtube.com/watch?v=3ni1Pf-wwo0 ) to reduce dust. It seems like a very simple and effective way and I can use Henry without clogging him up can be done cheap too ( https://www.youtube.com/watch?v=9w8jXS8Fjh8 ) ____________________ Honda CBF125 ➝ NC700X
owl |
owl World Chat Champion
Posted: 23:58 - 04 Apr 2017 Post subject: |
Hi wood people, can someone help please.
Missus bought a spice rack and then of course because she possesses (that's a lot of s's) a vagina has decided now that she doesn't like the spice bottles in the rack and wants to use other spice bottles that don't quite fit in the hole (that's what she said).
It's really close, so close that you can force the new bottles in.
So my question is, is there such a. Thing as an affordable circular wood planer that does holes like this?
https://s11.postimg.org/5qqyc8ktf/IMG_5538.jpg
Width needs to increase not depth.
Or do I need to go to work with some sandpaper?
Maybe a drill and some sand paper would work somehow? ____________________ Observation is the greatest source of wisdom. |
mentalboy |
Posted: 02:05 - 05 Apr 2017 Post subject: |
vice wrote: | Hi wood people, can someone help please.
Maybe a drill and some sand paper would work somehow? |
Pics from a US retailer but you can buy this kind of thing at places like B&Q. The small shaft fits in a drill chuck. The paper rounds just slip over the rubber bung and then you tighten down the nut on the end which compresses the bung, increasing its diameter, thus holding the paper in place.
https://www.homedepot.com/catalog/productImages/1000/a0/a04bfb6a-2568-42d6-942e-a7c19b810416_1000.jpg ____________________ Make mine a Corona. |
zark |
zark Trackday Trickster
Posted: 08:18 - 05 Apr 2017 Post subject: |
^wouldn't that be tricky to keep it circular?
Have you thought about forstner bits? assuming you've got space above to actually get a drill in. ____________________ CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou... |
ScaredyCat |
mentalboy |
ScaredyCat |
Posted: 23:35 - 19 Sep 2017 Post subject: |
So I've been playing about and I made a chopping board.. Nothing special but I'm getting there Learned a few lessons along the way on this one.
https://www.dropbox.com/s/m6jlwjb0dbfhlp8/board3.jpg?raw=1 ____________________ Honda CBF125 ➝ NC700X
Suntan Sid |
Posted: 00:56 - 20 Sep 2017 Post subject: |
Go on then, don't keep us in suspenders, how did you make it?
I'm assuming you used a thicknesser to finish it, or did you go old skool and hand plane it flat? ____________________ "Everybody needs money, that's why they call it money!" |
ScaredyCat |
Posted: 08:29 - 20 Sep 2017 Post subject: |
stinkwheel wrote: | That's cool/
AMazing how good modern glues are isn't it? |
Yeah, the bond is supposed to be stronger than the wood fibre bond. Titebond II is what I've been using.
stinkwheel wrote: | What did you use? Polyurethane? |
It's just a light coating of olive oil. I did a huge amount of reading about it. Lots of people saying it'd go rancid. Thing is, the oil will wash out when you wash it, so unless it's never used I don't see the problem. Lots of people saying use mineral oil, not sure about that myself but I might get some to try.
Suntan Sid wrote: | Go on then, don't keep us in suspenders, how did you make it? |
Lots of thin bits of wood glued together and clamped. Even with my best efforts they move about quite a bit so you need to push them down onto a flat surface. I just put greaseproof paper on a table and glued them up, pushing down on each bit to try and get it flat. The greaseproof paper stops it sticking to the table. I left it for about 30 minutes then moved it onto another bit because of all the glue squeeze out. Waited another hour and scraped off as much of the glue squeeze out as possible.
Suntan Sid wrote: | I'm assuming you used a thicknesser to finish it, or did you go old skool and hand plane it flat? |
I hand planed it, don't have a thicknesser yet and I'm quite keen to keep it hand tools only for as much as I can right now. I have a distinct lack of space and have 'converted' half my office into a workshop. By converted I mean moved stuff out of the way. I can't be generating loads of chippings and dust. Sanding gets done outside, when it stops raining. Using a Henry with HEPA bag to clean up.
Not all of the bits of wood I used were the same size but rather than hand cut them all down I thought it'd be much easier to just hand plane it when the glue dried. That bit worked very well. Once that was done I did 80 grit to remove the remaining, then 100 grit. After that I made the board wet so the grain rose up. Let it dry and used 120 grit on it, then 240. The wetting makes the grain rise, you sand it down so it's smooth again and this stops it going all rough when you wash it.
I'm also in the process of building a table top workbench, the workmate is just too wobbly for anything serious and the lack of clamping power is a real pain, especially when hand planing.
I might make a mallet in the same way, think it might look quite nice. I've made a couple of other bits too, but workshop things. A shooting board and a magnetic saw guide. I made those just to make it feel like I was getting somewhere nice easy things to make to boost confidence.
Really do like the Japanese saws too. Got a Ryoba being delivered tomorrow, they leave an awesome finish. I already have a crosscut one, but I should have got the Ryoba instead, that gives you two cutting surfaces, one crosscut and one rip, on the same blade. ____________________ Honda CBF125 ➝ NC700X
fatjames |
fatjames World Chat Champion
Posted: 14:21 - 20 Sep 2017 Post subject: |
Here's a bit more woodworking.
I installed a stair gate for a friend, it had to be screwed into the flats on the banister on one side and the wall on the other. This meant it was higher than she ideally wanted it and left a gap at the bottom. (only about 180mm)
I made this:
https://i.imgur.com/FgP5Ukz.jpg
It was quite simple, ripped some batons then cut to length. Shaping was done with sand paper.
Holes were drilled using a forstner bit in my el cheapo drill press then all glued and clamped together. (titebond II)
I'll do some further sanding and finishing before attaching it to the existing stair gate.
The shape looks bit strange, but the stair gate is adjustable and this extension just matches the profile at the required extension.
You might notice the dowells aren't perfectly lined up, this is purely as I was rushing and didn't bother setting up a fence / stops on the drill press.
I need to make another for the gate at the bottom of the stairs, I'll take a few more photos next time and make sure the dowells are lined up properly. |
CaNsA |
CaNsA Super Spammer
owl |
The last post was made 6 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
