chris-red |
Paris2 |
Paris2 Nearly there...
temeluchus |
MCN |
MCN Super Spammer
Posted: 17:26 - 25 Jun 2018 Post subject: |
You need to do an efficiency test on the cooling system.
Quite intensive task follows. Theoretically simple but interesting results.
You will need:
a thermometer at the thermostat/regulator housing. A glass one out of the chemists Not a baby one as they do not go high enough.
Try to sort of 'lag' them with rags and tape to prevent them losing the 'measured heat' but have the probe part touching metal to allow heat to conduct to the bulb/probe.
a thermometer at the top tank of the radiator.
a thermometer at the bottom tank of the radiator.
Run the engine and record the temp at 5 min intervals.
Do this until the fan switches on.
continue for another 4 or five readings.
You are trying to find out if the cooling system is cooling the engine effectively.
There should be a very slight drop between the regulator housing and the top tank. If your thermometer is sensitive and accurate enough you will see 1 degree C. Or more.
The main readings you are looking for are top and bottom tank.
The radiator should cool the coolant to be at least 10% cooler than the top tank. If so then the cooling system is good.
If you cannot see at least 10% drop from top to bottom then either the pump is no good or the radiator is blocked internally.
The last thing you should do is invest in taking the head off just yet.
You must be 100% certain of the head problem or you will do the work for nothing and meet the same problem after.
Mostly, head problems cause combustion gasses to blow into the coolant. It will displace the coolant if severe.
Is the water pump is easy to get to I would whip that off before pulling the rad off or the head.
____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
stevo as b4 |
Posted: 18:17 - 25 Jun 2018 Post subject: |
How certain is OP that they have no noticeable coolant loss? If almost certain there is so coolant loss, what does the coolant look like? I.e is it just a bit scummy but antifreeze coloured, or is it rusty brown or oily?
It's entirely possible for a radiator to leak externally, or alternatively for tubes inside to get blocked or damaged or collapse, as they are quite delicate things.
I agree with all the sound advice given so far in this thread, but before doing a cooling rate test across the rad, I think I would on my own bike just replace the expansion tank cap/radiator cap, and test or replace the stat too. If a new radiator wasn't daft money I'd probably be forking out for one, not a scientific way to solve a cooling problem, but it's three of the hardest working components in the cooling system, and radiators take a bloody pounding from road debris and any objects flung up hitting them etc.
When doing a coolant flush and re-fill, I think I'd get a water pump gasket too, so you can take the cover off and check both the impeller for damage/corrosion and the inlet and outlet ports to the pump body too.
I'd spin the engine over on the starter with no plugs in or the leads off, and check that the pump rotates too. The reason for this is from reading an article in CMM about a cooling problem on a staff members bike, which the drive to the pump was done via a jackshaft and 90degree bevel gear driving the pump shaft, which had failed.
I've also heard of people doing effectively a leak Down test on parts of the cooling system, where they pressurise the cooling system with air and monitor if and for how long it holds pressure for as a test.
I agree with not taking off a cylinder head until everything else has been eliminated, as head gaskets rarely just fail without one or more fairly obvious signs. There's a world full of people out there that have replaced head gaskets without ever fixing their engines cooling system fault, to find out there was nothing wrong with the head gasket in many cases. |
Paris2 |
Paris2 |
Posted: 11:58 - 26 Jun 2018 Post subject: |
Also want to thank everyone for the sound advice so far.
Very helpful, just what I expect from this forum ____________________ Current Ride: Daytona 600 |
Paris2 |
chris-red |
P. |
P. Red Rocket
Paris2 |
Posted: 16:27 - 29 Jun 2018 Post subject: |
It is exceptionally warm at the moment, so I'm taking that in to consideration.
I have seen 120 countless times though over the past few weeks, but never above that. And it does cool when I get moving over 20mph or so.
Maybe I should just remove the fairings ____________________ Current Ride: Daytona 600 |
Paris2 |
Posted: 10:02 - 02 Jul 2018 Post subject: |
FIXED
Worked out a few more air pockets in and around the pump. Did about 400 miles over the weekend, and didn't overheat once.
Hurrah ____________________ Current Ride: Daytona 600 |
The last post was made 5 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
