Serf27 |
Serf27 Derestricted Danger
CaNsA |
CaNsA Super Spammer
Serf27 |
jaffa90 |
jaffa90 World Chat Champion
Suntan Sid |
Copycat73 |
Copycat73 World Chat Champion
WD Forte |
WD Forte World Chat Champion
Glover |
Glover Two Stroke Sniffer
chris-red |
Serf27 |
Posted: 01:52 - 21 Dec 2016 Post subject: |
Thank you for the replies everyone!
Got some time to work on it and here's what I did.
CaNsA, I turned the idle screw up all the way, it helped some, but still experiencing it dying sometimes when stopping.
Jaffa90, I am using an aftermarket pod filter, it does not have the original air filter box, the filter is brand new, got it today.
Could this be an issue since it's not the stock filter?
I checked the float needle position when I first cleaned the carb, but did not adjust it or anything. I couldn't find the spec for it on this bike online, I will need a manual to adjust the height.
The float needle is good though.
The bowl is getting plenty of fuel though, when I loosened the bowl drain screw, fuel did come out of it for a few seconds.
Suntan Sid, I did sand the ends of the coil(pack?)where it mounts to the frame to clean metal, also sanded a small ground wire that bolts with it, also sanded the actual frame where the coil is bolted onto. Not sure if it helped a little but problem still occurs.
Copycat73, I bought a new plug and put it in, stalling still occurs.
WD Forte, I did not check the exhaust seals, I will check those possibly tommorow and tighten the exhaust if it's loose.
Glover, my bike doesn't have lights, but thanks for the input.
Chris-red, I adjusted the clutch cable the other day but I think I may have adjusted it too tight, as the clutch lever does not have enough play I have seen when people on YouTube asjust theirs. I will remove the case cover and clean the clutch discs possibly tommorow
Here's what I have done and bike still stalls.
-Idle screw that holds the throttle cables on the carb, turned all the way up for highest idle.
-Cleaned the carb and jets, twice.
-Installed new spark plug.
-Bought new air filter, guy at the bike shop said the pilot jet was dirty and causing this, I did not find the pilot jet on the carb diagram but assume it was one of the jets I cleaned since I cleaned the carb up and down, side to side.
-Rode the bike with the idle air screw set at these different settings, all started with air screw tightened till snug.
•Turn screw out 1 turn.
•Turn screw out 1 1/2 turns.
•Turn screw out 2 turns.
•Turn screw out 2 1/2 turns.
Should I try 3 turns out?
The bike will start fine when cold, usually less than 5 kicks.
Once started cold, it will idle fine.
It drives fine and is a fun and semi fast bike for trails and just fast enough for my experience.
When coming to a stop though, I have to give it gas a little and keep the throttle open just a tiny bit to keep it on.
On RARE occasions, when I stop, I can release the throttle slowly to keep it on, but 95% of the time releasing the theottle slowly it will just start to bog and die.
I can't remember how it idles when I start it warm.
I will clean the clutch pack to see if they are sticking, like Chris-red said, I think I have seen this symptom online once before with someone else with the same issue.
I will also check the exhaust seals as WD forte suggested.
Other than that I am out of ideas, besides tightening the throttle cable more to open the throttle more, since the screw for it is holding the throttle as far open as it can.
Thanks again all for the replies and help, any more help is greatly appreciated! |
Dimerz |
Dimerz Nitrous Nuisance
Serf27 |
ADSrox0r |
ADSrox0r World Chat Champion
Serf27 |
Posted: 07:24 - 21 Dec 2016 Post subject: |
Thanks for the reply ADSrox0r.
The inlet boot for the carb to head is in good shape.
What I forgot to do was to replace the gasket that connects it to the head. I will replace the gasket and see if it helps.
Thecarb slides into the booth nicely and made sure the boot and carb ends were clean, forgot to replace the gasket. |
ADSrox0r |
Serf27 |
Serf27 |
jaffa90 |
Serf27 |
Serf27 |
Serf27 |
Posted: 03:11 - 24 Dec 2016 Post subject: |
Update: I cleaned the carb a 4th time. Took it down to the bare carb body, and had it soda blasted at a shop for safe measure.
The carb has a pod filter, I got these new pieces:
Pilot jet size 20. stock jet is 17.5
Main jet 170. Stock main jet is 155-165.
And some o rings.
Good news is the bike would bog like crazy with the air filter on, and run good without the filter, the main jet was too big! It had a 180 main jet, I dropped to a 170 and it's much better with the air filter now.
Semi good/bad news, the bike will stay on most of the time coming to a stop if the choke is on, but the choke always moves it self to "off" and I have to reach down, put the choke on when stopping.
Bad news is it won't idle without choke on will die coming to a stop.
And if it doesn't die, it will BARELY stay on, like will bog badly and as soon as it sees throttle, it dies.
The choke on this bike is an enrichment choke I believe, do I need to get a bigger size pilot jet since it only idles when the choke is open/on giving it more fuel? |
Serf27 |
Posted: 19:27 - 28 Dec 2016 Post subject: |
Finally!
The idle screw on the bike was the wrong one and was too short so it would bottom out before it would start to increase the idle.
I got a longer screw and was able to open the throttle slide a bit more and now it idles fine with no choke and I can come to a stop comfortably!
Thanks everyone for the help. |
ADSrox0r |
Serf27 |
jaffa90 |
The last post was made 7 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
