kramdra World Chat Champion
Pete. Super Spammer
Posted: 15:45 - 18 Dec 2016 Post subject: |
Usually easiest to pull the TB's off the rubbers. If you can get the clips right off you might be able to break the bond using a pair of large pump pliers by gripping over the connection and very slightly twisting the rubber but you have to be uber-careful not to tear it. Usually I just grab the throttle bodies and 'hinge' them up and down a few times to crack the bond. ____________________ a.k.a 'Geri'
Posted: 17:13 - 18 Dec 2016 Post subject: |
IIRC, I've replaced the cables on the same bike without removing the TB's, I remember it being a ball ache but I got it done.
If you have to remove 'em, do as Pete says, alternatively, if you're feeling brave, what I did to get the rubbers off, when I replaced mine, was pushed a thin blade screw driver down the side of the TB's and rubbers and worked them loose as best I could.
When I got them off, which wasn't a quick job, they hadn't been damaged and could have been used again, had I not had new ones to fit!
But that method's always going to be a gamble!
When you get the new cables fitted, make sure they're routed correctly under the front of the tank, it's very easy to trap the cables, on the frame just behind the headstock! ____________________ "Everybody needs money, that's why they call it money!" |
Copycat73 World Chat Champion
